New ATP Ball Bearing Setup
Old Dec 15, 2010 | 06:26 PM
  #61
spdracerut's Avatar
Originally Posted by RevMoto
Am I the only one wishing they are going to make a gtx2876r model for the auto-x guys
That would be a pretty bad mismatch of wheels. The 2871 is bad enough. The GTX3071R would be your best bet.
Old Dec 15, 2010 | 06:45 PM
  #62
JmanMR's Avatar
i'm highly interested in seeing how these turbos perform
Old Dec 15, 2010 | 07:34 PM
  #63
Azlan of Narnia's Avatar
What is the difference between the GT3582 and the GTX3582? Is the GTX the HTA compressor wheel?
Thanks
Old Dec 15, 2010 | 07:46 PM
  #64
Evolutionn's Avatar
Have you herd of an fp white?
Old Dec 15, 2010 | 08:01 PM
  #65
Bramage_Dained's Avatar
I bet they don't sell many until after a well known shop tries a couple out.
  #66
JesseB's Avatar
Thanks
Garrett's new billet wheel version. HTA while also a billet wheel refers to Forced Performance's line up of compressor wheel upgrades.
Old Dec 16, 2010 | 05:58 AM
  #67
discopotato03's Avatar
Are these TS turbine housings a Garrett item or are they something ATP gets for them ?
I'm not so sure Garrett would do a GTX 71.1mm compressor for the GT2871R series , they already have too much compressor in the 56 comp trim version .
I think Garrett is going to run out of cheap solutions once the GTX compressors become mainstream . Really the gap is a bit big between the GT28 NS111 turbine and the GT30 UHP turbine .
For reasons only they know they don't want to use the 60mm (GT30 sized) version of the NS111 9 bladed turbine in their production turbos . It is used in competition spec TR30R turbochargers and would be a great asset in some GT30 based turbos .
Cmon Garrett we WANT that 60mm NS111 turbine for power with response ...
Old Dec 16, 2010 | 06:12 AM
  #68
EVO(boss)'s Avatar
wow ...
Old Dec 16, 2010 | 08:13 AM
  #69
EvoJoeIX's Avatar
Fp turbos are not ball bearing turbos
Old Dec 16, 2010 | 10:04 AM
  #70
03whitegsr's Avatar
Garrett needs to do a GTX28XXR. If they could manage 45-47 lb/min and an exducer under 65mm, it would be pretty great for the auto-x guys. That GT28 turbine wheel owns. I had a GT2871R and it was pretty wicked. It might be a mismatch, but it still worked well with 25 psi by 3500RPM on a stock block 2.0L. My stock IX turbo doesn't even do that up here.
Old Dec 16, 2010 | 11:56 AM
  #71
VGergo's Avatar
just why dont you buy a HKS ?
Old Dec 16, 2010 | 02:25 PM
  #72
03whitegsr's Avatar
I could care less about stock frame turbos, otherwise I would get the FP White with the TME titanium turbine wheel. It is off topic, I was just commenting on discopotatoes post.
As for this topic, I don't see how this is a "stock frame" turbo though. At least the FP, HKS and Tomie turbochargers all retain a stock like look despite having non-OEM housings. This thing just has the stock turbine housing flanges and NOTHING else. I don't think these would qualify as "stock appearing."
Old Dec 16, 2010 | 03:56 PM
  #73
06MREvo's Avatar
Yeah, I was wondering this also. Since I run the stock appearing turbo list, I was going to setup a survey and see what everyone says...
Old Dec 16, 2010 | 04:08 PM
  #74
EvoJoeIX's Avatar
yea def not a stock appearing turbo since its not made from the stock turbo housings
id classify it as a stock location turbo
Old Dec 16, 2010 | 04:22 PM
  #75
[I.R.A.]_FBi's Avatar
aha so more bolt on than stock appearing?
