BBK-Full Tuning Issue!!
Old Dec 18, 2010 | 10:14 AM
NitrousOxide's Avatar
Originally Posted by evo7vii
Well I would stress making a thorough boost leak test and make sure that ur TB seals are leak free
I mean as previously said u sould be able to pressurize it and be able to hold 30 psi with no major
Leaks.
On the other hand, we can't call a tuner who is been doing a great job for more than 7 years in the UAE
Unprofessional. Your car having a problem might contributed to such unstatisfying gains but then again
Mustange dynos do read low.
More clues...hmmm well it was the only yellow M3 on campus with sponser stickers.
I completely agree that mustangs read low, but benchmark the torque to HP n u'll realize somethings wrong!!
n lets not forget that my turbo makes well over 400 on a mustang dyno.. you just heard CBRD speaking above
I gave him the car with some codes and everytime I ask him what is this he replies "wallah ma ba3ref"... It was my worst experience with a tuner, I'm being honest!!
Old Dec 18, 2010 | 10:34 AM
Originally Posted by CBRD
Send me your rom,
you should pick up a 3 port, and Ill send you a basemap.
cb
Thank you very much.. I'll send you my rom and let u know once I recieve my 3-port
06MREvo's Avatar
OP...With your mods you should have no problem hitting 400whp...I hit a little over 400whp on Chad's dyno at 26.5-27psi & a conservative timing MAP...Fuel wise you are probably fine with 780cc injectors but I would suggest throwing 1000cc injectors in there and not worry about it at all...Also you are still running a stock 02 housing?? I would definitely suggest throwing in a larger 02 housing or maybe an 02 dump if you like those...Is your BBK Full ported? If so an 02 housing would make the exhaust flow a bit better coming out of the turbo to the 3 inch exhaust...
Old Dec 18, 2010 | 10:39 AM
G20's Avatar
G20
hmm! some discrepancies here. i don't believe the 780cc can handle 30 psi and i don't think you can run that amount of boost on 93 oct gas unless the '93' over there is higher than 100 here.
Old Dec 18, 2010 | 11:56 AM
CBRD's Avatar
I run 30 psi on 93..
cb
EvoSupersonic
Dec 12, 2012 10:37 AM
kreionic
624
Nov 29, 2011 05:04 PM
Pure EvoIX
Aug 8, 2011 05:42 PM
ilikeboost
Jun 10, 2011 12:58 PM
snafufx
Oct 17, 2009 11:51 AM
