Some current oil analysis info, ongoing testing.
Old Jan 22, 2011 | 04:15 PM
  #61
Jeffs2006EVOIX's Avatar
edited by jeff
Old Jan 22, 2011 | 04:17 PM
  #62
edited by jeff
Old Jan 22, 2011 | 06:05 PM
  #63
apagan01's Avatar
Originally Posted by Jeffs2006EVOIX
Sorry for the Horrible photo, my Blackberry takes horrible pictures.
But you get the idea.
Jeff
get an HTC EVO, 8 mega pix's camera
Old Jan 22, 2011 | 08:03 PM
  #64
cij911's Avatar
Jeff - The actual oil temperature is at least ~ 20 - 30 degrees hotter. The OE sensor is in the oil drain plug. If you move the sensor to the plugs in the oil filter housing, you will see the temperature rise . Still I rarely see more than 200* (VDO gauge with sensor in oil filter housing).
Old Jan 22, 2011 | 08:44 PM
  #65
TommiM's Avatar
Can I tap into the oil filter housing with a 1/8" npt sender or do I need some adapter? How do you have yours set up?
Old Jan 22, 2011 | 09:00 PM
  #66
cij911's Avatar
Tommi - There are two plugs that can be used on the housing. I use one for the oil pressure sending unit and one for the FP oil line. I currently use a VDO drain plug with integrated oil temperature sensor (previously I had a VDO sensor in one of the two holes in the housing).
You can get the gauges and sending units at 42 Draft Design (they have very good how to's as well). I personally like VDO gauges - quality and clean look.
http://store.42draftdesigns.com/Lanc...ptor_p_54.html
http://store.42draftdesigns.com/VDO-...ware_c_22.html
Call them if you have any questions....
Old Jan 23, 2011 | 09:40 AM
  #67
GG06MR's Avatar
^^^+1. My DEFI gauge mounted to the oil filter housing reads a pretty consistent 180F in cooler temps while cruising on the Interstate.
Old Jan 23, 2011 | 10:57 AM
  #68
edited by jeff
Old Jan 23, 2011 | 11:06 AM
  #69
edited by jeff
Old Jan 23, 2011 | 07:43 PM
  #70
GG06MR's Avatar
I would have to disagree with what you are saying on this Chris. I am not disagreeing that there is an oil temperature variance, but that would be throughout the whole lubricated part of the motor and where the oil comes and goes.
I believe, that the 20-30F difference you saw is not the fact that your new oil temp location is giving a more accurate temp which is implied, I feel it is more that the fact of where it is placed. The oil pan is Steel. The oil Filter housing if I am not mistaken is Aluminum. We all know that Aluminum absorbs and dispresses heat better than steel. My belief to why your temps are 20-30F higher is simply because the aluminum is absorbing the heat from the oil and since the sensor is screwed into that alum housing, it too is getting the heat.
Either way, its minimal. In my OEM guage's case, its in Celsius and 30F diference on a Celsius gauge is only 1 degree. So if your looking at my gugae as pictured, can you tell me the difference on 1 degree Celsius? Thats the point im making.
Anyway, either way, the oil temp guage is just an APPROXIMATE temp anyway, no matter where it is mounted.
When I solo II or am on the dyno I never see temps over 100C which is about 212F and in day to day driving I never see over 80C and in the heat of the summer (120F where I live) I see around 90C.
The guys that I know that race, and when I mean "race" im not talking solo 2 stuff like I do, they do Time Attacks, pushiing 500-700whp Evo's around a track at 150+MPH and when I look in their Evo's what do I see? The OEM guage pack that came in ther RS's. When I ask them why dont you run better guages this is their reply, "Jeff, at a 150MPH + the last thing I am looking at is a guage, and this 2.0 is so strung out that if oil pressure drops I know it before the guage does".
So take that for what its worth.
Here is a pic of my guage gooing to work this morning. Again, I feel these temps are a good APPROXIMATE temp (My guage is in Celsius not F). Again, no need for a 50w oil.
Jeff
Think about it this way. The thermostat opens at 180F(82C), so does it make sense that your oil is consistently 20F(or more) cooler than your coolant?! I'm pretty sure that's a no, so realistically 180F is going to be your minimum oil temp once the engine gets FULLY warmed up.....unless I'm way off base.
Old Jan 24, 2011 | 12:49 PM
  #71
edited by jeff
Old Jan 24, 2011 | 02:42 PM
  #72
GG06MR's Avatar
Water Temps and Oil temps are different
Yeah
but what I am getting at, is either location is not a real accurate measure of what the oil temp is. Just a good approximate as I have said. At EITHER location.
That may be the case, but if one reads normal temp at or above what coolant temps are at, and the other reads below normal coolant temps, then I think it's pretty obvious as to which location is MORE accurate than the other.
The Water guage gets its reading at a far more accurate place than the oil does, and even there for the water is still an apporximate temp.
That supports my point more than it does yours.
don't forget the oil cooler has a thermostat as well. I just don't know exactly when it kicks in to open up the oil cooler.
I bet it's close to 190-200F
Bottom line is, neither location is ideal. Its just an approximate oil temp in either case.
In general, I can agree with that. I think they're a great tool for saving you from a potential engine rebuild, but the more accurate they can be the better.
Old Jan 25, 2011 | 08:29 AM
  #73
edited by jeff
Old Jan 25, 2011 | 02:44 PM
  #74
apagan01's Avatar
Anyway, its irrelevent to Tommi's Thread and I am sorry for posting that pic up. Now back to the VOA's and UOA's of which this thread was started anyway. Bickering over 30F difference in Oil temps means almost nothing in 95% of all Evo's on the road anyway. Its just getting silly.
Jeff
Thanks Jeff, for considering the main reason of this thread.
Tommi, of course me being the AMSOIL guy is should have a bank of lab results comming this way, for SSO, HDD, dominator VS mobil ect.... once ig get some time to upload and find them i will
Old Jan 25, 2011 | 04:38 PM
  #75
GG06MR's Avatar
The only reason I put the pic up was to prove that in my particular case, and most likely 90% of all Evo drivers out there, you really don't need or ever will need a 50w oil. The oil temps just don't get high enough to justify it. Even the Redline 5/30 I am running now, if I was tracking the car hard and saw higher oil temps, the Oil would still be in good shape. For me to exceed the temp range of this Redline 5/30 I think something else would go before the oil would IMO. So the guage is not the "Bible" of oil or engine health.
Agreed.
My point on the placement of a sensor in the oil filter housing is this. I said it once and I will say it again and be done with it. You are stating because you have higher temp readings there that is your justification that it is a more accurate reading. I disagree with that. BOTH places are Approximate. The reason why your seeing higher temp readins IMO is the fact that your sensor is placed in an aluminum housing of the oil filter. Aluminum absorbs heat quicker and disapates heat quicker than steel. The aluminum housing is getting hotter by the hot oil going through it. Thus your have hotter temp readings. Not that they are more accurate. Again, its a good "approximate" as is the oil pan. I seriouisly doubt that the 1 foot difference in the sensor loaction is going to make the oil cool down 30F.
Could be lots of things other than just the location too, like the quality of the sensor. Not all sensors are created equal right?! Regardless, I wasn't saying that the reason it was more accurate is just because it reads a higher temp in that location, but instead because it reads a higher temp that's logically appropriate for the temp at which you'd expect the oil to be when it's temperature regulated at a much higher temp than 160F.
Agreed here too. I just took a sample of AMO 10W40 after 3K miles of use this last weekend that will be sent off to Blackstone hopefully by tomorrow, so I should be able to contribute to this thread in a more on topic manner here shortly.
