2k rpm idle?
Old Jan 1, 2011, 08:42 AM
evojoe90's Avatar
2k rpm idle?
my 03 evo has a high idle after driving for more then 20 minutes. cold start idle is normal. usually idles @ 1000 rpm because of cams. if i shut off the car it will go back to normal until i hit the gas, and then will go back to 2 k. please give me your advice. thanks
Old Jan 1, 2011, 01:31 PM
My03evo's Avatar
maybe bad tps or iac? or really sounds like a sticking throttle cable....when its at the high idle go to the throttle body and try to "close it" more and see if it drops back down or just rev up it and snap the throttle back to idle and see what happens.
Old Jan 2, 2011, 05:00 PM
evojoe90's Avatar
sometimes itll do it then itll go away a couple seconds later. revs go up and down varieing from 1k to 2k rpms. then sticks at 2k. throttle not sticking
Old Jan 2, 2011, 05:17 PM
meckert's Avatar
so you get tuned as well? Regardless, diconnect your battery to reset the ecu-- should help if not correct the problem-- sounds to me like the tune though.
Old Jan 2, 2011, 05:48 PM
evojoe90's Avatar
just ohm'ed out the tps and seems that the sensor is falty. goin to replace tomorrow
Old Jan 2, 2011, 06:02 PM
tscompusa2's Avatar
you can test the tps by using evoscan, no need to ohm test it. its really just a coil.
take your idle air controller apart and clean it.. sounds like its dirty.
In an EVO the closed loop vs open loop transition is based on airflow hz, not a idle switch or anything like the dsm's.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
rartist
Feb 24, 2017 03:46 PM
ezzey
May 9, 2016 09:40 AM
3volution8
Apr 23, 2008 12:25 PM
RSGuy
10
Sep 26, 2007 08:57 AM
Quick Reply: 2k rpm idle?
