hey i need help asap! big problem!
Old Jan 2, 2011 | 02:30 AM
shotgun_joshy's Avatar
Hey I was just driving home and I opened up the car in fourth gear a little and got what sounded like fuel cut so I let off and turned in to my driveway. I put the clutch in and tried to drive up my road but the car didn't move. After messing around with the shifter I realized I could put the car in any gear without pushing in the clutch. I got my tranny rebuilt by Shep like two months ago with a brand new clutch so what could it be? Anything helps...
Old Jan 2, 2011 | 04:43 AM
ddb's Avatar
ddb
I think that your throwout bearing unsnaped from your pressure plate. Simply jack the car and check via the small check hole (there is a small round rubber piece that you have to remove) from under the car.
Old Jan 2, 2011 | 05:14 AM
94AWDcoupe's Avatar
post 2 is not what happen. if that happen clutch pedal would stuck on floor and car would move cause clutch will remain engaged.
you broke something in drive line. sounds like clutch splines are stripped out. common with 7.25 twin plates and six paddle discs.
Old Jan 2, 2011 | 09:59 AM
R/TErnie's Avatar
maybe a broken shift fork/rails Jerry?
Old Jan 2, 2011 | 10:24 AM
shangai's Avatar
if you move the stick and its free, doesnt engage any gear. checks cables or maybe the bushing that goes to the tranny. maybe you lost the clip and they came off..
Old Jan 2, 2011 | 11:06 AM
Hey guys thanks for the already given opinions. I still don't know what it could be so im gonna talk to my buddies who are good with cars. Anymore info is still helpful
Old Jan 2, 2011 | 11:42 AM
barneyb's Avatar
I'd bet #3 has got it right - the engine is no longer connected to the transmission.
Peter Colindres
26
Mar 14, 2016 06:35 AM
2012evogsr
May 14, 2014 02:17 PM
polish_pounder
17
Feb 10, 2011 06:24 AM
m0nkie
12
May 2, 2010 06:03 PM
380254
12
Dec 13, 2007 07:38 AM
