Turbo outlet for Evo 9
Old Jan 6, 2011 | 09:00 PM
shogun's Avatar
Hi friends,Which o2 housing or turbo outlet has the good specs and would recommended to replace the factory unit. IŽll use the car in off-road competition
Thanks in advance.
Old Jan 8, 2011 | 07:51 PM
Brent_si's Avatar
Thanks in advance.
I am buying this one because of the good quality material used and quality of welding. Im not sure what the specs are but the external dump will make it have less exhaust to go through the system.
http://www.maperformance.com/jm-fabr...-dump-evo.html
Old Jan 10, 2011 | 02:40 PM
shogun's Avatar
Thank you Brent,will look at it
Old Jan 11, 2011 | 09:44 PM
evoiao's Avatar
just bought a mr o2 pipe but had to get it ported and polished a lot of roughness inside.
Old Jan 11, 2011 | 09:46 PM
mc14's Avatar
Search theres plenty info
Old Jan 11, 2011 | 09:47 PM
EVO Nate's Avatar
do you want to dump or are you just looking for more flow?
Old Jan 13, 2011 | 07:32 PM
shogun's Avatar
Just looking for more flow,so will have quicker response at lower RPM
Old Jan 14, 2011 | 11:47 AM
blknblubkrdude's Avatar
A 3" outlet would be your best bet performance wise, but a highflow aftermerket unit can be had for $45 to your doorstep on Ebay. Many people use these with great success on the dyno.
Old Jan 14, 2011 | 12:25 PM
ChrisCarey's Avatar
Here are a couple of the most popular options:
Megan Racing $109.99 Shipped
MAP O2 Housing $174.99 Shipped *11% rebate via gift certificate, use discount code 2011Rebate*
MAP External Dump O2 Housing $329.99 Shipped
Old Jan 14, 2011 | 05:24 PM
Brent_si's Avatar
Im sure one with an open dump would provide a little more power, not to sure about response. I might have to look into it. It also sounds insane on full boost.
Old Jan 15, 2011 | 07:01 AM
The MAP O2 parts are some very nice stuff indeed. My favorite vendor by far.
The dump housings will reduce restriction at full boost, but won't affect low-rpm response as the air won't by flowing out of both ports.
Here's the type which many people use:
http://cgi.ebay.com/ebaymotors/Turbo...item255f1e673c
I'd steer clear of the gasket they use, get an OEM one instead.
Old Feb 11, 2011 | 06:21 AM
Miroshnikov's Avatar
CONFIRM.
Ebay is winner here per price+perfomance.
MaLo EvoVIII
Feb 16, 2016 04:58 AM
vitalisevo9
Jul 18, 2014 12:19 PM
4g63evoeight
Feb 3, 2013 05:45 PM
FetorHepaticus
19
Mar 30, 2010 01:36 PM
BRN-EVO
Jun 17, 2009 04:52 AM
