New BW EFR Turbo Thread
Old Feb 8, 2011 | 09:10 AM
  #136
Lowso's Avatar
Originally Posted by Strm Trpr
I'm waiting on the 1.05 TS T4 EFR7670.
Can't wait!
This
Old Feb 8, 2011 | 09:36 AM
  #137
n2oiroc's Avatar
The iwg version wont fit an evo.
Originally Posted by SmurfZilla
GEOFF realistically what would be the price of a kit from your guys with this turbo. If it has a wastegate built in then that obviously lessens the cost.
I'm trying to determine pricing between this a regular ETS tubular kit with a HTA86 or a BR FF HTA86
Obviously the ETS kit would be cheapest. The BR kit will have some hidden costs (half width radiator, Civic Condensor and compressor for AC, etc).
I went on your site but I didn't see an option for the 8374 with you tubular manifold. It appears those would be the only things I would need. I already have upgraded IC and piping.
Old Feb 8, 2011 | 10:29 AM
  #138
ETS Michael's Avatar
We will build a custom kit around one of these turbochargers if any customer wants to send in the turbo or we can order the turbo since we are a dealer for BW turbochargers.
Old Feb 8, 2011 | 07:01 PM
  #139
SmurfZilla's Avatar
you have mail....and thanks for the heads up n2oiroc
Old Feb 8, 2011 | 07:03 PM
  #140
n2oiroc's Avatar
geoff said it wont fit, but in this thread it sounds like it may. i dont see how it would, but its worth checking out.
https://www.evolutionm.net/forums/ev...ct-review.html
Old Feb 8, 2011 | 07:39 PM
  #141
R/TErnie's Avatar
I think its possible, but it certainly won't be AC compatible.
sooo excited about this turbo
Old Feb 8, 2011 | 08:10 PM
  #142
JesseB's Avatar
Pretty sure that car doesn't have AC.
Old Feb 8, 2011 | 09:56 PM
  #143
Geoff Raicer's Avatar
Originally Posted by RSMike
pictures stolen from this thread, i hope he doesn't mind me using them.
http://forums.clubrsx.com/showthread.php?t=755332 GT3582R vs BW EFR 8374, both with 0.82 exhaust housing.
Please bear in mind that a correction factor of "SAE" is very easy to botch with ambient air temp sensor placement, i'd be much happier with uncorrected.
thanks for posting up, if you notice the chart shows "TCF 1.00" which means the correction factor is 1.0, so no games being played.
what would be the price of a kit from your guys with this turbo. I went on your site but I didn't see an option for the 8374 with you tubular manifold. It appears those would be the only things I would need. I already have upgraded IC and piping.
shoot me a PM with what you are looking for and ill get prices sent over to you, thanks
Old Feb 8, 2011 | 10:20 PM
  #144
RSMike's Avatar
Geoff please bear in mind that with the "SAE" correction factor, it uses the dyno's ambient temp sensor (which can be placed anywhere) to adjust the power output.
The temperature logging of the dyno should be shown.
Also If the "ratio" is out, it will multiply the output proportionally.
Also the length of the run (time) matters on how the graph looks.
Dotted green and Dotted purple line looks very similar to the same setup between a 8sec run and a 10sec run (although i'm sure it's not)
Now i'm sure these 3 things are all good, but i'm just saying Just trying to keep things honest.
Old Feb 9, 2011 | 06:41 AM
  #145
SmurfZilla's Avatar
Would the non internally wastegated 8374 fit?
Old Feb 9, 2011 | 07:03 AM
  #146
Ludikraut's Avatar
Yes, that already fits with the Full Race manifold. I really hope someone builds a kit to fit an IWG EFR turbo. I have no problems deleting AC...
l8r)
Old Feb 9, 2011 | 01:39 PM
  #147
Dragracer187's Avatar
Are the turbine wheels stronger then Inconel? Will they handle aggressive ALS type of launch control better, or are they comparible to Inconel?
Old Feb 9, 2011 | 02:03 PM
  #148
it will not fit a stock engine-bay evo 6/7/8/9 with Air Conditioning. If you are willing to lose A/C and can change up the radiator setup there are some options . I will be posting a lot of pics of these types of setups during the next few weeks. Evo X wont have these issues
We will offer it However for the Arizona desert, Ill be keeping AC and external wastegates on my evo
the Gamma-Ti has no problems with aggressive combustion and high EGT. This material is unique because it gains strength and ductility as temperature increases.
Geoff please bear in mind that with the "SAE" correction factor, it uses the dyno's ambient temp sensor (which can be placed anywhere) to adjust the power output. The temperature logging of the dyno should be shown... Now i'm sure these 3 things are all good, but i'm just saying Just trying to keep things honest.
Im confident the dyno operator was not playing with the ambient temp sensor (he is known as a straight-shooter). If I understand correctly, you may be confused on how people manipulate their dynos. According to an engineer friend of mine who owns a dynapack, you actually need SAE off, and then make the ambient temp ridiculously cold - that will give out absurdly high HP readings.
Old Feb 10, 2011 | 07:23 AM
  #149
acssa's Avatar
Dynapack is on the hubs and not the wheels... I estimate that the difference is about 7%....of what i have seen.
Old Feb 18, 2011 | 06:25 PM
  #150
EVOkeith's Avatar
Geoff, are you talking about the IWG 8374 fitting a non AC IIIV/IX? I hope there is a way to make this turbo fit.
