New BW EFR Turbo Thread
Hi Geoff,
I’m going to have a play around with the matchbot again. The last time I looked at it I found it difficult to use but I’m sure the tutorial will help a bunch so thanks for the vid!
I see you are recommending the 8374 for Time Attack and I'm interest to hear how Emp preferred the 8374. I was actually thinking of going for its baby brother the 7670 for my Time Attack build. My engine is a Long Rod 2.0L (as opposed to Sierra-Sierras 2.2L) and I'm hoping to have a long, useable powerband that tops out at 9500ish.
I've had some help on these calcs (cheers AndyF_RSX off the MLR)
Mass of air (g/s) = rpm/60 * displacement (l) / 2 * volumetric efficiency * air density (g/l)
Displacement = 2 litres
Target rev limit = 9,500 rpm
Volumetric Efficiency = 85%
Air density = 3.5 g/l (Lets say I plan on running 2 bar with an intake temp of 25°C)
Mass of air = 9500/60 * 2/2 * 0.85 * 3.5 = 471 g/s
Which converts to 28.263 kg/min = 62.18 lbs/min
If my VE was closer to 100% I’m hoping to get closer to 100% with a CNC ported head and a good set of cams (Jun 272’s).
So reworking the calc:
Mass of air = 9500/60 *2/2 * 1 * 3.5 = 554 g/s = 73 lbs/min
So according to those calcs and depending my actual VE figure, I should be looking for a turbo that flows 62-73 lbs/min? Which is why I was looking at the 7670 rather than the 8374.
What do you think would be the best match for me?
Thanks for your help in advance.
Cheers,
Karl
Cliffnotes:
Street setup that sees light weekend track days: 7670
Time attack or Street/Strip: 8374
Drag Racing: 9180
Drag Racing: 9180
Cheers,
Karl
***********Anybody interested in how to use the Matchbot Turbo matching software - watch this youtube video, It's a thorough and detailed walk-thru + info on the ins and outs of the software as well as proper values to target: YouTube - Part 1: BorgWarner MatchBot Turbo Matching Tutorial
Cliffnotes:
Drag Racing: 9180
Cliffnotes:
Drag Racing: 9180
I too am building a LR2.0L for my 2g Eclipse GSX.
1.05 A/R T4 EFR7670
JMF T4 TS Exhaust Manifold
GSC S2 cams
Curt Brown Spec 2g Head
Curt Brown Spec 2g JMF Drag SMIM
Shooting for 500 to the ground.
Should be a beast from 3500rpm up to 8500rpm no problem!
1.05 A/R T4 EFR7670
GSC S2 cams
Volumetric Efficiency = 85% ...
If my VE was closer to 100% I’m hoping to get closer to 100% with a CNC ported head and a good set of cams (Jun 272’s)... So according to those calcs and depending my actual VE figure, I should be looking for a turbo that flows 62-73 lbs/min? Which is why I was looking at the 7670 rather than the 8374. What do you think would be the best match for me?
i realize VE is a grey area, but one important thing to realize is that VE is not static and changes with RPM. For example, if you had a built 2.0 and intake mani/mildly ported head with good valvejob and some 272s, your expected VE curve might be something like this:
idle 80
2000rpm 83
2500rpm 87
3000rpm 92
3500rpm 95
4000rpm 100
4500rpm 103
5028rpm 106
6000rpm 107
7000rpm 107
7500rpm 105
8000rpm 103
8300rpm 101
the 8374 is definitely a high power turbo - making 700ftlbs tq at 5000rpm is unreal, according to Eric Hsu of Cosworth, the emp says this is one of the scariest fastest cars he's driven, and hes been seen shaking when he gets out of it
that powerband from 3500 to 8500 will be very very broad... you should definitely be able to reach those goals
Kins, if you're serious about spinning out to 9500 RPM, then you'd probably want the 8374, not the 7670. From what I can surmise, the 8374 would give you an effective power band of 4500-9500 RPM. With some tweaking it might spool a little sooner. Looking at the compressor map, I don't see the 7670 being all that effective past 8500 RPM, but the fun begins in the mid 3K RPM range - so a similar effective powerband. I did my calculations based on a target boost of 30psi and a 2.0L. I could go for an 8374 and rev my engine out to 9500 (it's been built and could handle it), but I will most likely opt for the 7670 because:
1. I want my car to remain streetable - hopefully be even more streetable than it is now
2. I don't plan on boosting much past 30psi, limiting how much I will gain from the 8374
3. and the engine should also last a little longer by not revving it out quite as far ... although it _is_ nice to have the extra revs on tap for those tracks where I can save a shift or two by holding onto whatever gear I'm in before the next turn.
l8r)
l8r)
The EFR 7670 is basically designed to give the same top end power as a gt35R but with much more bottom end... so yes I agree the 7670 would be a great starting point for a track evo build.
1.05 A/R T4 EFR7670 JMF T4 TS Exhaust Manifold GSC S2 cams Curt Brown Spec 2g Head Curt Brown Spec 2g JMF Drag SMIM Shooting for 500 to the ground. Should be a beast from 3500rpm up to 8500rpm no problem!"
How confident are you that on a reasonably well prepped 2.0L with the proper supporting mods, and using a Full Race manifold, downpipe and midpipe, the 7670 will be able to exceed 600 HP? I'm looking at the compressor map and had some question whether it can flow enough air within a reasonable efficiency range to make that level...
Don't know much about these turbo's
How would a 8374 do on a long rod 2.4 looking to achieve somewhere in the 700's for power?
I'm looking for more info on BW turbo's.
these are ROUGH equivalents
7670=35r
8374=hta86
9180=hta37r
Are you guy going to packaging these turbo's in a kit (Mani and DP?)
And thanks for the link.
I'd love to see a comparison to the HTA86 and 6262.
yes the EFR turbos are plug-and-play for our current twinscroll evo turbos kits, same kit
94mm stroke in a 4G64 will yield ~2.2L.
Get some 159mm rods and pistons with a compression height of 29mm.
That will give the user a 2.2L with a rod/stroke ratio of 1.69.
generally lr 2.4L is 100mm stroke and 156mm rod in a 4g64 block, correct? that sure doesnt leave much compression height. heck, if they can make a really strong piston with that compression height i might as well sell my 156mm rods for my 2.2L and get 162mm rods.
