New BW EFR Turbo Thread
Yeah Geoff I'm running a tspd sensor, but I haven't made the signal divider yet, so the ecu can't process the signal.
Dyno is Thursday at English. Unfortunately I didn't get my bbs wheels back from the powdercoater in time for the dyno... So I'll be denoting on the ccws and 295s
Without reading through 19XX posts, can anyone tell me when these will be back in stock in T3 internally wastegated versions? 7670 is specifically.. TIA
And where can I find info for the compatible manifold?
7076 twin would be my efr of choice. ofcourse it would be mounted to a full race mani aswell
Check this out Borg Warner EFR Turbos , should answer your questions (atleast if you know the basics).
btw: If you want to use this internal-WG turbo in a CT9A evo with airconditioning, it will probably have to be a top mount manifold like mine (requires evo6 style radiator)
I personally have ~4500 miles on my 8374. I dont keep tabs on my customers' usage but I am not aware of any reliability issues with the production EFR turbos. There was an early batch of B1 efr6258s that had faulty turbine wheels but those have been sorted, none of that carried over into the B2s that weve handled/distributed
455whp on 92 octane. 19psi
Turning up the boost made 525whp when I broke my driveshaft (due to my Moustache bar breaking in three)
Were going to hit up the dyno tomorrow.
Big props to the ER crew especially Jake for getting the driveshaft and Moustache bar swapped out in no time. We'll have some ER footage of the dyno session tomorrow.
Who was the maker of the mustache bar?
