New BW EFR Turbo Thread
Old Nov 4, 2012 | 09:12 AM
  #2131
Dave W.'s Avatar
Originally Posted by 03whitegsr
But do you have the same data on equivalently sized, twinscroll GTX and PTEs?
Also, how exactly was that recorded?
180kPa in 6ms means the turbo was already spinning fast enough to produce that boost. If anything, it was probably making that boost in the upper intercooler pipe and you are likely seeing the response time of the sensor and not the turbo. Scott from FP made some logs showing a similar situation where the MAP sensor sees vacuum under part throttle but the upper IC pipe had a ton of boost pressure and it lead to part throttle surge.
I'm not questioning if the response is great. I question if the data you have is really a fair projection of response. You said it yourself, unless you did a coast down from a higher RPM (like 7000RPM) to let the turbo speed minimize before the test, it really doesn't tell you much about true transient response.
Agree. This effect can be heard if you have a loud BOV. When you hold 5500rpm at part throttle the BOV should open due to pressure in the UICP and vacuum in the intake mani.
OTOH I'm not questioning the results, we just need data from an ordinary turbo for comparison.
Old Nov 4, 2012 | 09:32 AM
  #2132
R/TErnie's Avatar
my logger is at 50Hz.
I've taken data from the time from when the TPS is 100% until the kpa reaches these amounts. This is from vacuum, between shifts, etc. That's why I said it was an average from all my data. I keep record of time since last WOT, was it a 1,2,3 pull, or just a 3rd gear pull etc.
I have not done the T90 testing that I prefer to do. So I'm guilty of that.
I would like to test a HTA or GTX 3076 with a 1.0x A/R DividedT4 housing.... which means I'll need to buy one. I don't believe PTE sells anything that is competitive in that size, but if they do I'll be happy to buy it and test it this winter.
FP removed their T4 Divided housings from the 3076 options.
Old Nov 4, 2012 | 12:53 PM
  #2133
03whitegsr's Avatar
You got a PM...
Old Nov 4, 2012 | 05:14 PM
  #2134
Dave W.'s Avatar
Wouldn't the GTX3071 be a better match for the EFR 7163? They both have 71mm comp wheels and the GTX is rated at approx 56 lb.min. Precision has the new CEA turbine wheel in their billet 5558 which is rated at 590 HP.
There's very few options for a small turbo paired with a divided T4 flange. The EFR is unique in that regard.
Old Nov 4, 2012 | 07:10 PM
  #2135
R/TErnie's Avatar
agreed. I would think the 8374 would be easier to find PTE, HTA, and GTX equivalents for testing... however I have the 7670 and I'd like to do a bunch of comparisons against it while i still have this turbo.
I have SEEN a T4 1.0X A/R Divided housing on a GTX3076... I would guess that I could use that same turbine housing on the HTA3076 as well. The precision unit would need to sourced, but I could use the same turbine for both of those other turbos.
Old Nov 4, 2012 | 08:20 PM
  #2136
project_skyline's Avatar
If I can get a T4 housing worth a **** I'd test against a PTE and garrett. Have to wait and see what happens in the next month or two.
Old Nov 4, 2012 | 08:43 PM
  #2137
zertek2k's Avatar
7064 T4 1.05 on stock evo 5 motor(tired) with HKS 274/278 cams, ID1000's and Vipec ECU. Running on E-Flex fuel ( not the best but can buy it at the pump over here http://www.caltex.com.au/ProductsAndServices/Pages/BioFuels.aspx )Power is at the wheels.
Old Nov 4, 2012 | 08:48 PM
  #2138
MrLith's Avatar
Nice - Are the two runs the same turbo on different boost levels, or 98 vs eflex? How does it drive? What maxed out to stop you at 301awkw -fuel flow/turbo flow/bravado?
For the non-Dyno Dynamics initiated those numbers would probably equate to around 430-440whp on a Dynojet.
Old Nov 4, 2012 | 09:53 PM
  #2139
zertek2k's Avatar
The 2 different runs are boost, the 264 is 17psi and 301 is 21psi.
the stock 5 bottom end is not the strongest and mine has hard a hard life, I am building a motor atm for it, also at 21psi it was at 103% duty cycle on the injectors, im only running one Aeromotive 340 in tank atm so fueling is limited. When the new motor goes in I will go to twin 044's, ID2000's and 30psi and it should go 350kw, maybe more.
Drives really well, the graph makes it seem laggy but it is definitely not, pulls really well all the way through the rev range and just wants to keep going. Am super keen to get my new motor done and see how it goes on that. Fingers crossed it can hold boost to 9500rpm, I'm not sure the 7064 will hang on up top so may have to go to the 7670, but we'll see.
Old Nov 5, 2012 | 08:21 AM
  #2140
Apache's Avatar
I believe ATP makes a 1.06 twin scroll in a T3 housing for the GT30 and GT35. Not sure on the T4 side of things. Let us know what you find out though.
Old Nov 5, 2012 | 08:57 AM
  #2141
R/TErnie's Avatar
^ I've seen the t3 stuff on ATP's site. Which is usually where I go.
I think they might have disco'd the t4 housings due to "quality" issues.
Old Nov 5, 2012 | 09:09 AM
  #2142
240Z TwinTurbo's Avatar
1.06 a/r T4 TS still available
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
Old Nov 5, 2012 | 09:14 AM
  #2143
R/TErnie's Avatar
crap... I missed the tiny print that says...check this box if you want for a 3076 LOL.
$1830 out the door. I'll grab some more gaskets and fittings when I order it. Thanks!
Old Nov 5, 2012 | 01:46 PM
  #2144
khmerpimpin's Avatar
Should be a good comparison, kinda like what david buschur was trying to do to discredit efr turbos, but with actual data vs one another.
Old Nov 5, 2012 | 08:28 PM
  #2145
Geoff Raicer's Avatar
thanks for posting that info - what displacement are these motors? I read but did not see it, also what is your power target for this 7064? Im about to try a 7064 twinscroll on my 3.5L F150 motor
