New BW EFR Turbo Thread
Old Aug 12, 2011 | 12:31 PM
  #631
sho669's Avatar
Originally Posted by PATRICK B.
I'm sorry John but i'd like to clear things up for all those looking as to not confuse and spread rumors....................but the preliminary #'s i posted were just that preliminary #'s as the boost pressure could not be raised past 32psi and so the pulls were ended very short only 7000ish when the motor can spin to upwards of 9000 rpm.
I was busy getting my car prep'd for some new mods yesterday and i'm not 100% that our tuner would like the prelim. graph out but i will do my best to get it up here but it's by no means close to being tuned at 100%
Just figured I'd throw this back up, a lots still on the table with the car, 7k is a damn low cutoff point for a bigger turbo.
It would be like looking at a stock frame turbo chart and cutting it at 4500ish, of course the numbers going to read lower.
Old Aug 12, 2011 | 03:26 PM
  #632
R/TErnie's Avatar
Originally Posted by johnsm
its just surprising for me that at 32 pounds on E85 you made 550, when people at 25 psi make over 550 on E85 with GT35R sized turbos.
I think you're mistaking MD numbers with DJ numbers.
To make it somewhat equivalent...it's about 630whp on a DJ. Which should trap around 135~140mph depending on weight/traction.
Old Aug 12, 2011 | 04:00 PM
  #633
JohnBradley's Avatar
Originally Posted by 03whitegsr
"Much smaller"
In what regards?
The compressor exducer is 92.2mm compared to 94mm on the GT4294R. BW seems to measure backplate diameter and not tip diameter, it could easily be 94mm on the exducer with the extended tips?
It looks to be rated at 95 lb/min which puts it a hair under the 56-trim GTX4294R.
Just general information but this would be put it in the same class as the 3794 it would seem.
67.5/94 on the compressor and 92 lbs min observed.
Then again the 3586 is at 75 lbs and I made 794 with that.
Aaron
Old Aug 12, 2011 | 05:00 PM
  #634
project_skyline's Avatar
Geoff been great talking to you and again appreciate the info and all the help glad i posted this in here and made a good contact person in you for the future
I personally can't wait to see what this and the 9180 turbos do in full tilt mode!
FWIW on our MD a car making 550 HP in close to full weight will trap 135-140 mph
And that is more than often with higher boost pressures closer to 40psi
If this turbos stays on the car we have a couple of different options to help hold boost better up top we have been in contact with Geoff and will hopefully have some more #'s soon.
Post a graph already!!!!!!!!!!!!!!!
Old Aug 12, 2011 | 05:54 PM
  #635
PATRICK B.'s Avatar
I'M WORKING ON IT!
Car is sitting on the dyno as i type as we are trying something out while we await a new actuator that will allow us to run more boost!
I'll be sure to stick around the shop to see if i can sneek at least a pic of the graph if things go well if not than unfortunately we'll have to wait until we get the new part in hand and installed.
Good news is that the turbo will be staying on the Evo so we will have full test results shortly
Old Aug 12, 2011 | 08:16 PM
  #636
PATRICK B.'s Avatar
Well i tried my best to talk Sean into tuning longer but he has his son and wanted to get a head start on their weekend together
So not much to update but on a good note we have figured out a way for it to hold more boost until the new actuator arrives.
Just did a quick test to 38 psi and that's when Sean called it a night.
My PEACE offering
Old Aug 13, 2011 | 09:36 AM
  #637
03whitegsr's Avatar
Aaron
Isn't the 3794 running a 72mm major diameter turbine side though, considerably smaller then the 80mm turbine in the EFR9180?
On the compressor side, the 52-trim GTX4294R is 67.8mm inducer and the 51-trim is 66.8mm which puts it very close in size to the 9180 on the compressor side. No idea on rated flow of those GTX wheels though.
The GT42R turbine is 75.1mm on the minor diameter where the EFR is 73.6mm, which could give it a few percent higher power capability provided they have similar flow for a given minor diameter.
Either way though, it would seem the 9180 was meant to be a competitor to the GT42R on power.
Originally Posted by BorgWarner EFR Turbochargers Technical Training Guide November 2010
The 80mm wheel really means business. Made from our highest-flowing blade shape, this wheel is designed for maximum flow in view of our highest-power EFR customers. This wheel has delivered the goods for up to 1000whp (per turbo) and comes with a 92% exducer trim.
Old Aug 14, 2011 | 09:12 AM
  #638
Ang Wen Yan's Avatar
Originally Posted by skc
Just read through this thread - some interesting opinions for sure!
I had a couple of EFR 8374’s on order since late last year, and understand the general frustration expressed by a few in this thread. I finally managed to get my hands on one a week before WTAC to run on my otherwise tarmac-rally spec IX. After reading through all the dire innuendo expressed in a couple of forums, I have to say, we approached tuning the car with some serious reservations. In fact, if time had permitted, I am pretty sure we would have probably reverted to running either my HKS T04z or TS GTX3582 instead.
Tuning the car for a few hours the night before the event, it made an easy 424kw atw at 2.0 bar, despite the fact it was tied down with 6 straps and running soft R’s on the rollers. For reference, the same car, on the same rollers, with the same target boost made 417kw atw running the T04z. Although peak power was comparable, what really surprised me was the relative power down low. At 4500rpm the 8374 was making ~70kw atw more power than the T04z, despite the car now running a 0.2ltr less displacement with the new bottom end.
We took the car to WTAC and flogged it for three days, and the turbo didn’t miss a beat. Ignoring the numbers, trackside the real benefit from the EFR is throttle response. With the T04z, in some short corners I used to left foot brake and get on the gas early to try and get the turbo spooling and get drive off the apex. Now, with the EFR’s responsiveness, not only is the “left foot spool” redundant, there are a couple of corners where I am short shifting and driving out on the much more lineal torque.
We will get back on the rollers later next week and refine the cam timing and balance of tune and then see how it performs at 2.5 bar. My view for what it is worth; product introduction and packaging issues aside, I can’t see why you would run anything else based on what I have seen to date.
SK
Is the EVO in question Tilton Interior EVO?
If so kudos to you guys for being able to hang with big boy and #4 fastest time of the whole day
Old Aug 15, 2011 | 08:04 PM
  #639
juanmedina's Avatar
bump.... for graphs
Old Aug 19, 2011 | 10:48 AM
  #640
PATRICK B.'s Avatar
I'm back to update.
Well even with the new actuator from Geoff it still didn't do the trick unfortuantely
Geoff spoke to Sean yesterday and has a new spring being sent out to us so hopefully that will alleviate the issue and allow more than 40psi of boost.
Sean tried what he could but was only able to hold 35 psi and was not too thrilled with the boost plot so no graphs yet until he's happy with it.................it did make 590HP though
Old Aug 19, 2011 | 10:51 AM
  #641
Geoff Raicer's Avatar
hey patrick - i expected the new actuator that i sent you was too soft (it only had a 19psi spring in it) the big difference was it's a dual port, which is why you were able to hit 35psi on it. sean has it plumbed properly, and the new spring for the dual port canister is on its way
Old Aug 19, 2011 | 11:51 AM
  #642
PATRICK B.'s Avatar
Awesome thank you sir!
Glad you and Sean were able to speak to each other yesterday
I will update again when we have the new actuator installed and the car back on the dyno ....................
Old Aug 19, 2011 | 02:39 PM
  #643
This thread blows without graphs.
Old Aug 19, 2011 | 04:46 PM
  #644
houdini_678's Avatar
checked on this thread two months ago...
i'll check back in October...
wooo-tzz-tz-tz-tz....
Old Aug 21, 2011 | 01:20 AM
  #645
R/TErnie's Avatar
I guess I'm impatient. Any news?
