New BW EFR Turbo Thread
Old May 26, 2011 | 09:45 AM
  #436
CBRD's Avatar
yeah for sure- that is almost a perpendicular entry into the dump tube-
Old May 26, 2011 | 09:56 AM
  #437
Geoff Raicer's Avatar
Originally Posted by acssa
the oem oil supply has a 2mm/0.08' hole as seen above. I will have to check if that is ok.
CAUTION: THIS HOLE IS TOO SMALL FOR OIL FEED!!
the fitting that comes with the turbo is a -4AN PLEASE USE THIS SIZE FEED ORIFICE -4AN = 0.160" = 4mm
Old May 26, 2011 | 10:23 AM
  #438
acssa's Avatar
I am going open the hole with a dremmel...
Old May 26, 2011 | 10:41 AM
  #439
try and measure all points and enlarge anything that can restrict oilflow during startup. It is critically important that there is plenty of oil immediately upon startup
Old May 26, 2011 | 11:02 AM
  #440
Andy_8's Avatar
Mark Shead @ MADevelopments in the UK just fitted the EFR 7670 1.05 a/r on Raj Sobratee's evo and will dyno later this week. Check out the thread on lancerregister: http://www.lancerregister.com/showthread.php?t=373326
You might want to check that link again post 128
Old May 26, 2011 | 11:11 AM
  #441
project_skyline's Avatar
Ouch... that sucks.
Old May 26, 2011 | 11:29 AM
  #442
Mark S's Avatar
Originally Posted by project_skyline
Ouch... that sucks.
Dont be to worried as I do belive its just a faulty one and will be sorted under warrenty without a problem.
Mark
Old May 26, 2011 | 11:52 AM
  #443
Kins's Avatar
+1 I can imagine the Borg Warner EFR team will be very keen to get that unit back for a strip and inspection.
I'm sure Raj and yourself will have a replacement unit back in no time.
I guess we'll have to wait a little longer for the results though
Mark
Old May 26, 2011 | 12:04 PM
  #444
johnsm's Avatar
bump//.
Old May 26, 2011 | 01:05 PM
  #445
R/TErnie's Avatar
be sure to pull your plugs and crank your engine to build oil pressure prior to starting the engine with the new turbo... that way you've got oil in the lines prior to startup.
Old May 26, 2011 | 01:13 PM
  #446
Kins's Avatar
Nice tip but I think you're trying to teach your grandma to suck eggs if that tip is for Mark
Old May 26, 2011 | 02:05 PM
  #447
acssa's Avatar
space and manifold force the layout.... will test it...
Will be interesting to see the what happen.... WG will only open at 29 psi
Originally Posted by TiALSport
T'ing that gate into the other dump tube against the flow is not a good idea - you may throw off the balance of the engine and create excessive back pressure in the gate that is T'd in
Old May 26, 2011 | 03:36 PM
  #448
R/TErnie's Avatar
You could pull that tube closer to the other wastegate... totally possible.
To the other poster...I know that Mark Shead knows better, but I assume that there is a LARGE number of Evom member's who don't know to do it...or are too lazy to do so.
Old May 27, 2011 | 09:32 AM
  #449
erickponce's Avatar
I think you can also unplug the crank sensor wich is close to the oil fill cap to crank without starting so that you dont have to pull the plugs.
less work i think
Old May 27, 2011 | 10:50 AM
  #450
acssa's Avatar
another view after welded
