New BW EFR Turbo Thread
Old Jan 7, 2012 | 06:51 AM
  #1336
Turbotalon1g's Avatar
Isn't this a thread about those EFR turbo things?
Old Jan 7, 2012 | 07:05 AM
  #1337
Texas_Ace's Avatar
I see dyno numbers like this. No matter what dyno you use, the numbers it spits out are just numbers, they mean nothing.
I could care less if it is technically "1 hp", no dyno reads real hp, they all just spit out numbers.
The only thing that makes those numbers mean something outside of that particular tuning session, is if they are consistent. Doesn't matter what the numbers are, if every other dyno reads different, then the numbers are worthless on the internet as you can't use them to compare to anybody/anything else.
This is where the dynojet becomes the standard. Due to the way it works, there are no user adjustable settings to change the readings, meaning that all dynojets everywhere will read the same numbers, making the numbers useful as we can now compare numbers and actually have a worthwhile datapoint.
I have been to 2 dynojets in the same day, 1 a 248, the other a 224. Both read the same numbers. There is no way for the operator to screw with the numbers by loading the car differently or changing another setting. The numbers you see are the numbers you get.
I have seen people on load bearing dynos (mustang, DD, dynopak ect) change the outputted numbers at will with the push of a few buttons. That instantly removes all credibility for those dynos when it comes to comparing numbers IMHO. It also means that it is impossible to compare numbers even between the same brand since some shops have "low" reading dynos and others have "high" reading dynos.
That said I much prefer tuning on a load bearing dyno, they allow for a much better tune for sure. I just don't like the numbers they put out since they are so easily manipulated.
In the end, all dynos spit out numbers, none of the numbers actually mean anything, some are just more consistent then others, hence why they become the standard.
Old Jan 8, 2012 | 01:22 AM
  #1338
ItalianEvo's Avatar
Totally agree, but I (and not only me, but all the non DJ guys of the world) always see that DJ wHP are almost like load dyno FWhp (if load dyno was not inflated to replicate DJ numbers).
Agreed again, this absolutely is what people should understand.
IF load dyno is a modern one and the dyno's weather station works correctly so that SAE correction works well, it works great and gives consistent and repeatable numbers too, in a +/- 5% range.
This is what usually I see too, especially when the engine builder/mapper is even the dyno owner, numbers get inflated as well!
But if you leave a load dyno with zero correction other than the SAE one, it works great, in my experience.
Ah sure, there is absolutely no comparison between tunes made on inertial and load dynos.
Old Jan 8, 2012 | 01:28 AM
  #1339
ItalianEvo's Avatar
Originally Posted by mt057
How did this turn into a Dyno fight?
Seems like people have a hard time talking about politics religion and now Dyno's.
I would like to think that the majority of people realize that the Dyno is simply a measurement tool. It is best to compare Dyno numbers to a previous run on the same Dyno. In order to see the difference. Jumping from Dyno to Dyno and trying to compare is useless.
YES!
But let me again remind to those who don't know yet, that a non-US load dyno run usually gives at the FW your DJ WHP.
Should be, but EFRs do not exist... just an internet myth!
Old Jan 8, 2012 | 02:47 AM
  #1340
user 72082032's Avatar
Dynojets can be made to read way off too. Very easy. How many dynojet operators measure the coastdown losses after every set of runs, how many monitor wheel slip to ensure the strap tension is the same?
All dyno's suffer poor operators at times. There is no standard and that is the problem.
Old Jan 8, 2012 | 03:03 AM
  #1341
evo4nr's Avatar
There are two sets of cones , you enter the first set below 30mph then go for it!
The cars are weighed and have v-boxes fitted.
Originally Posted by Dave W.
How do the cars begin the run while keeping the contest fair?
This is an interesting alternative that would reduce variance from luck or driver skill.
Old Jan 8, 2012 | 12:42 PM
  #1342
Evo MR IX Fritz's Avatar
Old Jan 8, 2012 | 02:27 PM
  #1343
Originally Posted by ItalianEvo
YES!
https://www.evolutionm.net/forums/ev...cing-dyno.html
Says it all really!
Old Jan 17, 2012 | 02:34 AM
  #1344
gmx's Avatar
gmx
Originally Posted by 03whitegsr
Dude, I don't know what your problem is. We are on the same page that there is lots of BS going on with dynos.
I think the only difference between you and I is you seem to believe it only happens in the US? I'm saying I have no doubt it happens every where else too.
Point being, take dynocharts with a grain of salt no matter where they come from. I'm really not interested in this going further, you seem to think I have some point to prove about Dynojets when I certainly do not.
Oh, but for the record, NONE OF THEM measure HP. They calculate it either from a torque measurement or acceleration of a known inertia measurement.
Mainline dyno manufactured in Australia have different setting to those sold & shipped to the USA.
What he says is no bull****. This argument is on so many different forums and you yanks are all skeptical. I don't blame you. On the otherhand, ItalianEvo, who the **** cares
More results please, videos, roll on numbers, acceleration vids, spool vids. Cmon.
Old Jan 17, 2012 | 11:25 AM
  #1345
Mark S's Avatar
I have another 3 EFR 2 7670 to test in the next 6 weeks and a 8374 in about 8 weeks.
Mark
Old Jan 17, 2012 | 01:21 PM
  #1346
R/TErnie's Avatar
Mine is coming together I opted to hold off on the weight reduction and focus on the engine build.
Old Jan 18, 2012 | 06:09 AM
  #1347
Ludikraut's Avatar
^ good man! Time for results!!!
l8r)
Old Jan 18, 2012 | 04:17 PM
  #1348
Geoff Raicer's Avatar
i should be up and running in 2 weeks or so with my EFR 8374 .92 a/r - wrapping up final design detail on the Twinscroll EFR Internal-WG turbokit before finishing fabrication
Old Jan 18, 2012 | 06:17 PM
  #1349
Hi buddy
Old Jan 18, 2012 | 06:32 PM
  #1350
hey fritz
