Blown Transmission?
Old Jan 15, 2011 | 03:37 AM
bnr34rb26dett's Avatar
Exclamation Blown Transmission?
i have a buschur bushwhacker transmission in my evo and it started acting up today.
here are the symptoms
It does not want to go in reverse
when it does it slightly moves backwards
Its harder than usual to shift between gears and into a gear
i might have noticed some sound coming from the transmission while driving but not that noticeable of now
any comments/ suggestiosn would be appreciated.
i will try to get a video of it soon
thanks
Old Jan 15, 2011 | 08:46 AM
bump
Old Jan 15, 2011 | 09:06 AM
sho669's Avatar
clutch needs adjusting
Old Jan 15, 2011 | 09:09 AM
Thore's Avatar
Worn clutch? Sounds silly since it was rebuilt but maybe try changing fluid out?
Old Jan 15, 2011 | 02:45 PM
thanks for the comments
i will try changing fluid with AMSOIL later this week.
as far as adjusting the clutch goes, wouldnt it be weired for my clutch to not disengage as much as it used to? i mean if it was not disengaging (due to wear) it makes sense but the opposite? what could have caused this?
Old Jan 16, 2011 | 07:22 AM
anyone?
Old Jan 16, 2011 | 05:16 PM
wazmunstr's Avatar
try replacing the fluids first. how long has it been? you may be super low. fluids first man!
Old Jan 16, 2011 | 11:48 PM
snazzyseth's Avatar
possible slave cylinder problem too.
shane_evo7
Jun 11, 2017 01:26 PM
Jpenley
Mar 22, 2016 10:26 AM
ch53avitech
Nov 28, 2009 10:09 PM
mifesto
Nov 18, 2009 11:38 AM
pls1968
Oct 31, 2007 07:06 PM
