LR2.4L engine break-in oil recommendations
Old Jan 17, 2011 | 02:20 PM
RunThat's Avatar
I need to look into the bearing clearances to see which weight oil I will need to use for after the break-in
Old Jan 17, 2011 | 02:22 PM
BLKCarbonEVO's Avatar
If I were you I would talk to the guys building your motor!
Mikey
Old Jan 17, 2011 | 02:31 PM
meckert's Avatar
Originally Posted by Aby@MIL.SPEC
I used a straight 40w non-detergent for ~50miles (had to get the car home!) changed it, then went ~500 miles on a similar oil. been synthetic ever since, mobil1 15w/50 then amsoil 15w50.
i currently have ~11k on my 2.3L motor. This motor uses next to NO oil. The oil level is always near the top notch of the dip stick every 3k miles!
my stock 2.0L used ~1/2-3/4 qt every oil change (3k miles), bottom notch on the dip stick.
^^^^^^^THIS.
Old Jan 17, 2011 | 02:44 PM
RunThat's Avatar
Mikey
LOL! Obviously!!! I will do so tomorrow! Thanks for your help Mikey and everyone else!
Old Jan 17, 2011 | 02:48 PM
Just checking! lol Engine builders know the clearances of the bearing and what oil you should use. Different shops do break in differently though.
Mikey
Old Jan 17, 2011 | 04:13 PM
apagan01's Avatar
Synthetic is perfectly fis to break in an engine, with 10W40 or 20W50 high zinc and high phos oil,,, or get yourself some VR1 break her in cheap,,,
Old Jan 17, 2011 | 04:15 PM
agree VR1 will work out good
Mikey
Old Jan 17, 2011 | 04:24 PM
apagan01's Avatar
Mikey
Mickey he needs to get AMSOIL
Old Jan 17, 2011 | 04:27 PM
I told him a few posts above that the RD 15w50 would be good. motor break-in you can really use whatever. However, the RD would be nice after break-in! BACK UP OFF MY NADS!!!
Mikey
Old Jan 17, 2011 | 04:32 PM
RunThat's Avatar
apagan, and we discussed previously that the RD 15W-50 would be a good choice for when the motor is switched over to E98, correct?
Old Jan 17, 2011 | 05:03 PM
apagan01's Avatar
correct any alchohol based fuel used in a car should be using an oil that holds up to it,, its just good insurance since you will have peace that the oil is always lubricating,,,, now if you are dropping your oil every few miles or races than you may opt for a cheaper oil like VR1
apagan01's Avatar
Mikey
Old Jan 17, 2011 | 05:21 PM
Fast_Freddie's Avatar
Veteran: Navy
Andy, would you recommend the RD 15-50 or the Premium 20-50 for daily driving on 93/E85?
Old Jan 17, 2011 | 05:34 PM
apagan01's Avatar
yep or 10w40.
Old Jan 17, 2011 | 07:34 PM
RunThat's Avatar
Ok thank you! I am a clean oil freak most of the time and was planning on changing the oil every 2000 miles and/or after every race. I'll roll with the RD 15W-50 then since I'm quite nervous about the fuel dilution running E98
jimbo74
Apr 2, 2016 11:21 AM
apagan01
Sep 24, 2014 01:57 PM
apagan01
Feb 18, 2014 05:38 PM
babaz7
Jun 23, 2013 08:15 PM
