removing front axle
Old Jan 21, 2011 | 07:00 PM
anthonyrb98's Avatar
removing front axle
do u have to remove the dp to remove the passenger axle? i need to replace the seal at the tc
Old Jan 21, 2011 | 07:03 PM
psphinx81's Avatar
it would make your life a lot easier.. the dp is real easy to take off, take the extra five minutes and take it off
Old Jan 21, 2011 | 07:11 PM
how hard is it too remove the axle?
Old Jan 21, 2011 | 07:19 PM
ChanseEvo8's Avatar
Registered User
just like a honda remove the axle from the hub, use a pry bar to pop it out.
evomoto has a write up on clutch removal, its somewhere in the process if needed.
Old Jan 21, 2011 | 07:33 PM
wazmunstr's Avatar
yeah man it's very easy. I just did mine to take off my transmission. it will just pry right of with ease once you remove the ball joint to the control arm so you can pull it off the hub.
Old Jan 21, 2011 | 08:24 PM
how do u remove the ball joint
Old Jan 21, 2011 | 09:06 PM
wazmunstr's Avatar
dude,
http://www.evomoto.com/tech_articles..._article_id=27
Old Jan 22, 2011 | 04:24 AM
Berts24's Avatar
if memory serves me correct it's pretty much impossible to remore the TCase bolts without removing the down pipe......I understand you're trying to save yourself from doing extra work but sometimes the juice is worth the squeeze!!!
nor11384
Mar 2, 2016 02:51 PM
350EvoZ
17
Dec 1, 2014 06:47 AM
PedroMartinez
15
Jul 24, 2010 08:44 PM
FX11
May 12, 2009 08:04 PM
bboy_RES
May 12, 2008 09:07 AM
