What do you think about this?
Old Jan 25, 2011 | 06:39 PM
wht95scort's Avatar
I was going to make my own and was looking for a used one to use for mock up when I stumbled onto this. What do you guys think?
http://cgi.ebay.com/ebaymotors/Alum-...Q5fAccessories
Old Jan 25, 2011 | 06:45 PM
milford's Avatar
i just did some welding to my front mount to make it solid, then i started to think i might just weld up an entire cross member to try and cut some weight...this looks to be a nice alternative to the ams/buschur pieces. Nice find! i might try this out.
Old Jan 25, 2011 | 07:25 PM
wazmunstr's Avatar
looks legit. I have a solid mount on my cross member, but not made of aluminum!
Old Jan 25, 2011 | 07:29 PM
wht95scort's Avatar
Did you get any bad vibrations from it being a solid mount?
Old Jan 25, 2011 | 09:23 PM
wazmunstr's Avatar
I didn't even know it was solid until I pulled the transmission. previous owner had it installed. no vibrations at all! you would notice vibrations from the driver's side and rear mount, I believe.
Old Jan 25, 2011 | 10:57 PM
evolvd276's Avatar
you think the aluminum will hold up to 500 hp launches i looked at the same one yesterday ill prob give it a try
Old Jan 25, 2011 | 11:07 PM
BiFfMaN's Avatar
Its a flat peice of aluminum, looks like it would flex quite a bit.
I would be careful with that...the Steel (moly) ones have cracked, i dont see this being stronger.
Old Jan 26, 2011 | 07:12 AM
03whitegsr's Avatar
Link to any of the cracked ones? That's the first I've heard of it.
Looks like 1"x0.6" aluminum. Might be 1-1/2"x0.6" though. Either way, it's about 1/7th as stiff as the AMS bar.
Tubing is much more effective at carrying bending loads then solid flat stock bending about the thin direction.
Old Jan 26, 2011 | 12:37 PM
BiFfMaN's Avatar
Well mine (Bushur Lightweight Bar) has not cracked yet but yet i keep getting reminded a lot at meets that it will crack. And i am sure some has, Very possible if the other mounts are worn and the Solid mount now takes the load. I replaced the other mounts to Keep this from happening. It is working for me...how is yours?
When it does i will make a post on the internet to make it true for you ok
Old Jan 26, 2011 | 12:40 PM
n2oiroc's Avatar
not on a bet.
Old Apr 16, 2011 | 12:26 PM
milford's Avatar
anyone try this? how has it held up?
jan_ralliart
Sep 3, 2010 03:08 PM
09Ralli
May 15, 2010 09:15 AM
MattevoVIII
Mar 29, 2010 10:01 AM
EVO VII georgia
Nov 25, 2009 01:06 AM
Luke18
Oct 20, 2009 11:57 AM
