FP Red rebuild in another shop other than FP?
Hey guys,
As many of you know, my FP Red blew and I'm in need of a rebuild. With this said, I have already spoken with FP and they told me what I had to do to send it. However, by the way the turbo sounds I'm sure the compressor wheel and probably the turbine wheel will have to be replaced. Therefore I know it won't be $410 or the basic rebuild.
I was looking at the FP website and saw that they sell the basic rebuild kit for $100.00. and also sell the turbine and compressor wheels. I was speaking with the shop that always works on my car and he told me he can do the job. This would be of great benefit for me since I will probably have less down time and the job will probably cost me less since he is going to put the turbo back on.
I would like to know if any of you guys have ever rebuilt an FP turbo, know someone who has or if you guys have rebuilt your FP turbo this way(with another shop and not with FP). Please any advice will be greatly appreciated.
Thanks in advance
Thanks in advance
Have you taken the turbo off to check and see if your assumptions are correct? Something to note is that even though some things sound like they may have to be replaced that isn't always the case. Brian over there can fix compressor wheels, smooth out damage, and clip folded edges. Clipping was something very popular years ago in the DSM days as it increased spool up a bit. I actually just had my HTA86 turbine wheel clipped just a hair and was told it should free up some power which is interesting to say the the least.
I will let you know that I have attempted to rebuild another turbo (14B) myself and while it looked great and any shop could have done it just make sure they have the correct tools to balance it correctly as that's key a long with keeping clearances on both wheels in spec.
Either way, good luck
Thanks again
If your turbo needs new wheels, then it will need to be precision balanced after it is rebuilt. Each wheel is individually balanced and then the entire rotating assembly(CHRA) is balanced as a unit. I doubt that your local mechanic is set up to do this.
I would just go ahead and send it into FP. They do this for a living. If the compressor wheel is damaged then you might want to consider upgrading to the Black wheel. The Red and Black share the same turbine wheel.
. Any more info on this?
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
sikwititevo9
Aug 22, 2016 06:14 PM
TURBO_S2K
Dec 23, 2015 11:04 AM
ottoman
20
Oct 12, 2011 06:00 AM
), there is no rebuild kit for the FP Red. The only way to rebuild it is to send it to FP!
