35R fittings
Old Feb 3, 2011 | 09:34 AM
CtSilver03Evo's Avatar
35R fittings
Can someone please verify what the fitting sizes are on a Garret 35R? Will a -6AN and -8AN work for oil? What about coolant? Thanks!
Old Feb 3, 2011 | 09:43 AM
Evolutionn's Avatar
i use -4 feed, -10 return
and -6 for water...
Old Feb 3, 2011 | 09:52 AM
n2oiroc's Avatar
are you talking the actual thread pitch/diameter on the chra?
Old Feb 3, 2011 | 10:45 AM
TiALSport's Avatar
fitting with -4 feed for oil inlet
-10 oil drain
14 x 1.5 fittings for water - get 14mm to -4 fittings
Old Feb 3, 2011 | 11:42 AM
Damn... I was mislead (by a big-name DSM/EVO company too *not mentioning who*). I was told -6AN and -8AN for oil lines... That sucks seeing that I already bought some.
Old Feb 3, 2011 | 12:31 PM
mt057's Avatar
-10 oil drain
Do you happen to know what the oil inlet thread pitch is aswell? Does the HTA35R have a built in reducer or do you need a fitting with a reducer?
Old Feb 3, 2011 | 12:49 PM
TiALSport's Avatar
yep!
upper right hand corner
http://www.turbobygarrett.com/turbob...4568_7_8_9.pdf
she's a weird one
Old Feb 3, 2011 | 02:28 PM
mt057's Avatar
^ Thanks! That is a weird one...
Old Feb 4, 2011 | 07:13 AM
So, should I just scrap the -6AN and -8AN lines I bought then, and order up some -4/-10? Will they not work, or will I need reducers, etc.. to make them work? Just wondering if it's worth trying to use them or not.
Old Feb 4, 2011 | 10:43 AM
TiALSport's Avatar
if the -6 adapter has a .030 or .040 reducer you should be fine, personally i'd go with a -10 drain, more is better - remember, too small a drain and too large feed can lead to oily messes
STM Tuned
Jun 13, 2018 12:31 PM
mdsevo06
34
Jan 7, 2015 07:24 AM
CtSilver03Evo
Feb 23, 2011 08:49 PM
ryukinevo
Oct 18, 2010 07:30 PM
forum04pl
Mar 9, 2006 02:42 PM
