Hydrolocked my built 2.0L ... pics inside
Old Mar 2, 2011 | 02:46 AM
evilempire76's Avatar
Wow!! I've been trying to see that kind of power a manley h-beam can handle, but this certainly isn't the type of data I was looking for. Good luck with the new build.
Old Mar 2, 2011 | 03:16 AM
bbyevo8u's Avatar
how many miles & how old was the build?
Old Mar 2, 2011 | 05:16 AM
Phoenix*'s Avatar
Sorry to hear about this failure...
What mods were on the car...?
Did you have water/meth injection...?
Old Mar 2, 2011 | 05:29 AM
06MREvo's Avatar
holy crap! Good luck with the new build...Like some others have said, I am down for making a small donation to the new build...
Old Mar 2, 2011 | 05:35 AM
AlwaysinBoost's Avatar
man that sucks
hope you are able to figure out where the oil/fluid was coming from so it doesn't happen again.
Old Mar 2, 2011 | 05:37 AM
SEEnoEVO's Avatar
Wow that really sucks!! Sorry to hear about this man. I hope that you can figure out what happened as I am very curious along with many others.
Old Mar 2, 2011 | 06:49 AM
way2qik's Avatar
I did the same thing to a Mustang engine a few years back. Heads had been on and off the engine a few times, I skimped and didn't replace the head studs after torquing and retorquing them twice. Yes, they held the torque when I rechecked them with the torque wrench, but I had this "gut" feeling I should throw new ones in.
Well, I ignored that gut feeling and payed the price when pushing 25lbs of boost it lifted the passenger side head and allowed the cylinder to draw in water near the end of the 1/4 mile at over 165mph. Scary business when you're going that fast and you suddenly find your tires covered in oil and water.
Old Mar 2, 2011 | 08:43 AM
Fast_Freddie's Avatar
Veteran: Navy
Jesus...
Old Mar 2, 2011 | 09:27 AM
wreckleford's Avatar
Just curious why you think it hydrolocked and not just that it threw the rod from piston or rod failure?
Old Mar 2, 2011 | 09:28 AM
^ cause the rod is bent.
Old Mar 2, 2011 | 09:37 AM
If you throw a rod it will get all screwed up. Was the small end still attached to the piston/wrist pin? What did the piston itself look like?
Were you running pump, pump and meth or E85?
Old Mar 2, 2011 | 10:25 AM
recompile's Avatar
I'm runnning pump + meth. It popped under light accelleration in rush hour traffic at around 5psi.
The bearings were fine, the crank was fine, the wrist pin was fine, and small end of the rod was fine... it just bent and broke. The piston itself got bounced around and mangled up, but the head and valves seem untouched.
Old Mar 2, 2011 | 10:38 AM
wizzo 8's Avatar
OH !! Couldn't have happened to a better person. I'm in for donating to your motor build.
Old Mar 2, 2011 | 10:53 AM
MSD EvoVlll113's Avatar
i did the same thing to my dodge ram it sucked good luck man
Old Mar 3, 2011 | 11:57 AM
bambooi's Avatar
Of course, the inevitable question "what's next?" Well, I've ordered a BR 2.1L Destroker and BR Stage 3 MIVEC Head. I've already got a bunch of other parts awaiting install... most notably an HTA86 and a Garrett 3.8" Core FMIC.
Can't hide money! What clutch are you going with now?
recompile
Aug 3, 2019 08:12 AM
teudmunki9mr
12
May 27, 2012 12:10 PM
teribble
May 2, 2012 12:30 PM
recompile
For Sale - Wheels / Tires
Feb 21, 2011 04:28 PM
recompile
Jun 5, 2008 10:56 AM
