Installing an exedy twin disk rebuild?
Old Mar 8, 2011 | 06:30 PM
joseph143's Avatar
i'm a retard... i guess i skipped that post...
Old Mar 8, 2011 | 06:52 PM
wizzo 8's Avatar
Originally Posted by joseph143
call me crazy but your plan to machine the flywheel right? or atleast replace it... not sure if i missed that tidbit of info... when i researched rebuilding my twin carbon i remember matt gold saying to machine the mounting posts between the flywheel and pressure plate... the same thickness as what was cut off the flywheel... if you dont then say if you cut .02 off the wheel and the discs normal wear out is .075 they will now wear out at a thickness of .095... hypothetical number that are only for demonstration btw...
Look at post #4
Old Mar 8, 2011 | 10:38 PM
My03evo's Avatar
Originally Posted by wizzo 8
There are normally 2. I added an extra 1 but you really need one of these
https://secure.buschurracing.com/cat...3ae5e0ee14bcb2
How do you add 2 clips?
Old Mar 9, 2011 | 03:44 PM
wizzo 8's Avatar
There are 2 clips or wave washers already there from the factory. I just added one more to prevent the tob from pooping off during fast shifting.
Old Mar 9, 2011 | 11:23 PM
8UpUrV8's Avatar
I looked at my reciepts and I stand corrected.
I paid a little under 900 for the 4 discs/plates and new TOB
Old Mar 9, 2011 | 11:30 PM
8UpUrV8's Avatar
And I'm surprised it doesn't have it's own thread but..
Anyone with a clutch fork stop must adjust it every 8k miles or so.
My clutch started slipping and it was because the fork stop must be adjusted for wear.
Old Mar 10, 2011 | 05:47 AM
wizzo 8's Avatar
Yes I had the same problem and was pretty angry since I thought my clutch went out. Turned out the stopper just needed to be adjusted
manthny18
Mar 11, 2016 10:20 AM
manthny18
Feb 19, 2016 10:16 PM
GHEvo8
10
Nov 1, 2014 01:52 PM
JeyEvo
Aug 13, 2014 11:44 AM
krazykorean84
Feb 25, 2011 11:25 AM
