Fix My ACD Problem and I will pay you!
Old Jun 14, 2011 | 06:07 AM
  #91
timmiii's Avatar
Anyone had a chance to rebuild their pump yet?
Old Jun 21, 2011 | 12:31 PM
  #92
black95tt's Avatar
I'm going to attempt to rebuild the extra one I have. I don't have my IX anymore so I am also going to rig something up to test that it meets the pressure requirement. I'll keep you updated.
Old Jun 21, 2011 | 12:34 PM
  #93
jamevo8's Avatar
I had the same problem last year... only when it was hot out the lights came on then went off at night when cool out...
New ACD pump $2400 all fixed now
Old Jun 29, 2011 | 05:20 PM
  #94
thatmr2guy's Avatar
After all this time I finally got the replacement pump put on and I am working. Bleeding the unit was a pita but my buddy fixed it up and now everything is peachy. Now the real question is why are so many of these pumps failing with low miles (40K)!!!!
Old Jun 29, 2011 | 08:51 PM
  #95
Nashou66's Avatar
Found some links that are for the AYC.
http://image.img-erento.com/1420214/4314834.pdf
http://www.lilevo.com/mirage/EVO%208...0003300-27.pdf
Think I'll try to take mine apart this summer. But first i need to change my timing belt and a full brake job too.
EDIT: Just found this pic in the how too section.
I might move my pump to the trunk as well, this would save an expensive pump from the harsh elements of Western NY.
Nashou
Old Jun 29, 2011 | 09:18 PM
  #96
killerpenguin21's Avatar
i solved my issue. some ***** hit my car in the drivers fender...so im getting a new one through insurance since its cracked.
still interested to see if they can be rebuilt since in my ownership of the car i will probably have to deal with this again with how ****le they seem to be.
Old Jul 6, 2011 | 12:03 PM
  #97
timmiii's Avatar
Anyone rebuild their pumps yet?
Old Jul 19, 2011 | 04:09 PM
  #98
Davedangerous's Avatar
what he said!
Old Jul 19, 2011 | 06:22 PM
  #99
596736's Avatar
Originally Posted by black95tt
I drove my car for over a year with all three lights on. There are no negative effects. When I finally did change my pump out the car drove exactly the same, at least I couldn't notice any difference in daily use. On a track that may be a different story. From what I understand, and someone correct me if I'm wrong, if the pump fails you still have the regular function of an LSD in the center diff. It just won't lock up when the ECU calls for it, ex. when accelerating in a straight line. Basically it will be like an Evo VIII.
Can this be confirmed ^^^
If the acd pump is shot, will the TC be ok?
Old Jul 23, 2011 | 03:13 PM
  #100
justastockevo's Avatar
i'm still running my rebuilt pump, and it goes strong.
Old Jul 23, 2011 | 03:22 PM
  #101
Gocu619's Avatar
Justastockevo... Who rebuilt your pump? How much did it run you?
Old Jul 23, 2011 | 04:33 PM
  #102
me along with my friend's mechanic. approx 1k miles, but i don't drive the car much. runs just as good as new.
pictures of how to do it are within this thread. one small part is missing though, you've got to disassemble and clean the valve too, but you can just pour gas into it or maybe wd40 to make it clean, i guess it just doesn't matter much.
Old Jul 23, 2011 | 08:16 PM
  #103
Gocu619's Avatar
So, was there any parts that you had to replace and had to buy or just basically cleaned it out and re-bled the system and started working? How long did it take you guys and are there any special tools needed to disassemble it? Thanks
Old Jul 23, 2011 | 08:23 PM
  #104
Gocu619's Avatar
justastockevo.... sorry just read your post #36 and #39. so if fault code 82 is what im getting most likely my pump is corroded or i wont know until i take it apart? I want my pump to work, i gotta plan this out though. hopefully it can be fixed without taking it to the dealer or buying a new pump.
Old Jul 29, 2011 | 07:52 AM
  #105
timmiii's Avatar
I'm about to break open the motor cover for my pump to see what's up I'll get some picture for you guys by tonight or tomorrow.
