late spool up
Old Mar 31, 2011 | 09:56 PM
sparky's Avatar
scary pic. Looks like you need a new turbine housing.
Old Apr 1, 2011 | 09:51 AM
dirtylilevo's Avatar
It drives soooo much better now. I actually have trottle response. We had to weld a bead on the actuator arm inside of the turbo after the bushing because it was lose and by the picture you can see, not seating correctly.
Old Apr 1, 2011 | 10:44 AM
dinok's Avatar
^^^ what were the symptoms u had b4 u took the turbo out ??
was it the same symptoms as the ones i have listed ??
Old Apr 1, 2011 | 12:29 PM
dinok's Avatar
Old Apr 1, 2011 | 12:52 PM
turbotalawd's Avatar
Originally Posted by dinok
I know your frustrated, but just because he had that problem doesnt neccessarily mean you have the same problem. Go out to your car and inspect/do a boost leak test and let us know what you find so we can help you.
Old Apr 1, 2011 | 01:07 PM
dinok's Avatar
i see ... im just thinking if i had a boost leak wud i be still hitting full boost ?
bc the vac meter is the same as it always was
the only issue is the late spoolup
tomorrow im gettin it checked out
Old Apr 1, 2011 | 01:15 PM
You still would be hitting full boost if the leak was small. I know the fuel pressure regulator hose tends to pop off maybe you can do a visual check first.
what turbo/hotside are you running and what mileage is on it?
Old Apr 2, 2011 | 09:08 AM
I was hitting full boost (21psi) @ 4800rpms in 5th. I checked boost leaks, my hallman mbc, my bov, I adjusted my actuator arm, and finally pulled the o2 housing n saw my problem. N WALLLAAHHHHB! SPOOLS @ 3800
Old Apr 4, 2011 | 12:11 PM
dinok's Avatar
so did u replace the wastegate ?? bc i have a brand new bov and hallman controller
im pretty sure my wga is ****ed wasnted to see how u fixed that problem
Old Apr 5, 2011 | 12:55 AM
I welded on a small bead to keep the arm from backing out again.
Does that make sense? I guess I couldve taken a pic of it.
Old Apr 5, 2011 | 08:36 AM
dinok's Avatar
i was just curious if replacing the wga wud be the same thing
blkdrgn09
25
Aug 5, 2015 04:57 AM
mczellers
Apr 24, 2015 06:59 AM
JV21804
19
Oct 30, 2013 11:03 PM
alex the great
Mar 23, 2013 09:48 PM
blazersman
Apr 7, 2009 11:00 AM
