JohnBradley's 2011 car update.
Old Apr 6, 2011 | 03:42 PM
  #106
3gEclipseTurbo's Avatar
Man up an rev out to 9k while your at it
Old Apr 6, 2011 | 03:45 PM
  #107
JohnBradley's Avatar
Originally Posted by razorlab
Now that you can control dwell,etc with the stock ECU it might be helping a bit.
Seems to be what I am thinking as well. I have the dwell about where a 2G is (we did 1009whp/48psi on stock 2G once upon a time) stock. I am curious to see if I switched back to a beefier ignition if it would pick up more. Like I said budget isnt there with my racebike and quad season right around the corner.
Aaron
Old Apr 6, 2011 | 04:05 PM
  #108
tscompusa2's Avatar
Originally Posted by JohnBradley
These are the GSC H beam which are actually beefier than the Manley H beam. In talking to Greg he says to man up and go for it. I am thinking if I am going to do a bigger rod and piston then I would probably drop to a 2.2 and rev it out again with this combo. Lots of data to process before I make a decision, its looking like a larger housing (since spool is same right now) and then the downpipe and get nutty.
oh ok.. im glad i said [or whoever makes them then]. well in a way you're doing him a favor by pushing his product to hp/tq limits its never seen before, so he should back you if you're willing to take that risk imo.
Old Apr 7, 2011 | 10:01 AM
  #109
R/TErnie's Avatar
Nice work Aaron... I look forward to seeing what you'll do with more fuel
Old Apr 7, 2011 | 11:58 AM
  #110
Greg has been beyond generous with parts, tech, and willingness to listen me rant about the weird tech bouncing thru my brain Him, Luke, and Jeff listen to some odd things from time to time
Aaron
Old Apr 7, 2011 | 12:02 PM
  #111
kangzta's Avatar
geez! sweet build!
  #112
Whats the weight of the GSC h-beams compaired to the manley h-beams?
Old Apr 7, 2011 | 12:20 PM
  #113
n2oiroc's Avatar
They really arent in the same category, the manley h beams arent nearly as strong.
Old Apr 7, 2011 | 02:02 PM
  #114
GSC are 602g for the 156mm.
Old Apr 7, 2011 | 04:20 PM
  #115
JC evo1's Avatar
how much hp are you giving up in the midrange with the timing that low? Seems like going back to a 2.2 with full timing would probably make similar midrange but be better up top.
Old Apr 7, 2011 | 05:02 PM
  #116
project_skyline's Avatar
He was comparing them to the manley I beams, not the H beams.
Old Apr 7, 2011 | 05:03 PM
  #117
Someone else brought up manley h-beams was just wonder the differnce in weight.
Old Apr 7, 2011 | 05:09 PM
  #118
Oh well I know that when I talked to aaron on the phone about manley I beams and he said the GSC H beams were somewhere around 100g's lighter iirc then the I beams.
Old Apr 7, 2011 | 05:18 PM
  #119
BLKCarbonEVO's Avatar
Ya I know my GSC I beams are lighter than the Manley I Beams but I can't remember what the GSC I Beams weigh, hold on I'll find out.... Ring, Ring, Ring, Aaron picks up the phone, "English Racing, this is Aaron how can I assist you?", "Hey Aaron it's Mikey, what is the weight on my GSC I Beams", Aaron answers.....................
Mikey
Old Apr 7, 2011 | 05:23 PM
  #120
Mikey
I thought Aaron said you have GSC H-beams?
