AEM BEWARE!!!, Tuners please look, AEM vs Motech vs Microtech
Old Dec 22, 2003 | 02:20 PM
  #91
Pesto360's Avatar
JR I do appreciate what youre doing and sticking by your word...dont get me wrong..better late than never...and IM sure this will ring loud and clear for those who want an aem after you get this resolved
Old Dec 22, 2003 | 02:30 PM
  #92
954DRGSR's Avatar
Originally posted by badlooser
What about Haltec?
SFP is a qualified Haltec shop.
  #93
954DRGSR's Avatar
AEM seems like a good product, but after all is said and done, it still seems to be that the company should have done more preliminary testing before releasing the Evo version.
Old Dec 22, 2003 | 02:54 PM
  #94
JR From AEM's Avatar
Thanks,
We got your message loud and clear. Just hang tough and all will be well in the end. I promise you that and have already told the same to Frank @ SFP.
JR
Old Dec 22, 2003 | 02:57 PM
  #95
potsuVIII's Avatar
What system has fuel and ignition-in-one???
Electromotive TEC-3 is the answer. It's not a plug-n-play but definitely the one to consider. http://www.electromotive-inc.com
Some of you don't like it but some do. You'll be the judge.
Old Dec 22, 2003 | 03:01 PM
  #96
potsuVIII's Avatar
Hey JR! How's Mr. Siebels/JS. I know he's working on another project and no doubt it'll be something to look out for.
Old Dec 22, 2003 | 03:03 PM
  #97
We had a long meeting about that this morning. I know that it may seem that way and in this case, the ignition problem proves it, but looking at it in hindsight is easy. We put many, many hours on the evos, including a magazine dyno shoot with over 350hp and had no ignition problems. The main reason was that there were no big turbo kits/cars available at that time. We were running 18-20 psi on the stock turbo and having cars running mid 12's. We had no indication that we were close to the limit on the ignition. Also, just think how difficult it would be to "sell" someone on loaning us thier new evo:
Customer: What do you want it for?
AEM: We want to run really high boost
Customer: Is there a problem?
AEM: Not that we know of, we just want to be sure
Customer: How mush is really big boost?
AEM: Oh, about 25-28 lbs
Customer: Will this void my warranty
AEM: Most likely yes
Customer: Will my clutch get burned up?
Customer: Well, gee, no thank you.
Thanks,
JR
Old Dec 22, 2003 | 03:15 PM
  #98
kcevo's Avatar
JR
JR,
I am glad you have replied to this post informing us that any ignition problem with the EVO box will be fixed. I am definately waiting cuz i have the 5th box made (SN: 30-1313-0005).
Have you guys tested your C2DI along with the EVO EMS box? Did you do test it with the stock ignition or a coil on plug setup?
I have the C2DI box on its way and plan on installing it w/o changing to a coil on plug setup, and would like to know ahead of time if you guys at AEM tried this and ran into any problems?
Old Dec 22, 2003 | 03:17 PM
  #99
gt40's Avatar
JR,
I have run an aem on my car since the first week of november through brainstorm and gotten 3 hard track days + daily driving at 18 pounds boost and really tightly gapped plugs in the low 400 range. Felt I was just starting to make progress and now I am concerned again as I was when I raised this a month ago and posted my spark scatter issues and dyno chart that looked so bad with really uneven power up top.
I look forward to seeing a resolution to this issue. The key is what the company does at this point. Mistakes suck, but the manner in which they are taken care of is much more important.
Note to pass on to everyone at AEM: Just fix it! Do so in a timely matter and keep things productive on the information flow... share early and often.
I have read "claims" that aem has "great" support. Here is an opportunity to prove it one way or another.
Kudos to you JR for at least stepping up here and addressing everyone- it's not a solution but its at least a start.
A final question: Is upgrading the ignition one way to fix this? It would be nice to run power with the stock but I have msd blaster sscoils with an aem c2di to put on.
I am wary at this point to proceed...
Old Dec 22, 2003 | 03:30 PM
  #100
MrBubbler's Avatar
so JR could i bring my car in with upgraded turbo and my aem and have you guys tune it then i have yet to install mine because i am just now getting turbo kit and everything installed! but i want some one to tune it right and this would give you the chance to try tuning one with bigger turbo and everything else on the car = / let me know!~adam
Thanks,
JR
Old Dec 22, 2003 | 03:32 PM
  #101
Originally posted by gt40
JR,
...A final question: Is upgrading the ignition one way to fix this? It would be nice to run power with the stock but I have msd sscoils with an aem c2di to put on.
[/B]
Yes,
Changing to a CDI and new coils makes this problem go away.
JR
Old Dec 22, 2003 | 03:36 PM
  #102
MrBubbler's Avatar
wow so how much does that cost on top of the ems and uego ??? if i would have only known the ems was going to be a peice and make me buy probably more than 1000$ more worth of other products. i would have never bought it! this sucks thanks JR!
Old Dec 22, 2003 | 03:38 PM
  #103
Originally posted by kcevo
...Have you guys tested your C2DI along with the EVO EMS box? Did you do test it with the stock ignition or a coil on plug setup?
Yes, We have used the CDI on the EVO but, you cannot use it with the stock coils. They have an internal ignitor and can only take an ignition trigger signal. Putting +540v to them will blow them up instantly.
This is not an AEM EMS or CDI problem, you cannot run any aftermarket CDI with the stock EVO Coils. You will have to replace them.
Thanks,
JR
Old Dec 22, 2003 | 03:42 PM
  #104
DynoFlash's Avatar
Let me say this...the BEST reviews come from customers who have been through some tough times with their cars...and I have to tell u something on a scale of 1-10..I give frank an 11..He told me there was a beta box in another customers car...but he was also told there was a completed box..which was in MY car....I have seen every delay and every hitch, the only delays, hitches or malfunctions through this all have been on the part of aem and a few other suppliers ... as a matter of fact my car came out better than expected in alot of ways...and I am SO HARD TO PLEASE...those who know me can tell u that...when somethign needed to be done..frank was there..when we were on the dyno until 10:30 pm...u didnt hear a peep out of him...when my AEM blew..and I was stuck on the side of the road....he was over like AAA in a matter of minutes..when we thought we had AEM licked and completed..he was wiling to go dyno my car on a sunday after he went to church....come on...if youre going to comment lets know what we mean...Frank has had perhaps a hundred hours into this problem solving for them...YET he doesnt complain..I only know this because one of the guys in the shop I overheard talking about it...You should all wish you had a local guy like frank...Im not a cheerleader but Im very happy with SFP.net...I think even the guys at AEM will back me up on this..and so will anyone else...evertime my car comes back its spotless...everytime u see my car there its spotless and if it isnt...he has it cleaned...his other customers are happy u can see it ...this guy knows his ****..lets not start a flame thread....if you guys were really sincere about your aem issues...you should all thank Frank for putting in FREE hours to work this out so you guys can get your aems workign faster...we are all supposed to work together here thats what this thread was started for..and I purposely stated in the beginning that we needed it ito stay like that...I kow I have blamed aem for alot...but look what Ive been through..
PS al...you and me have a mutual friend alex who has your old DP
Down Pipe form my WRX/STI???
BTW - Did Frank ever get that new unit from AEM to test that they promised????
I just hope they post the progress up here so can now what s going on - I was hoping to send in my ecu over the holiday for the upgrade of the ignition but dont look like it is going to work out
Old Dec 22, 2003 | 03:43 PM
  #105
MrBubbler's Avatar
so whats the solution do the people who already own the ems get an exchange for the new version or are we just screwed? JR what is the most straight forward solution....without spending more on stuff the ems should already do.
