Cylinder heads, short blocks, flow benches....
I can't wait to see the results David. I think the argument that most of your customers will be interested in your "less hardcore" stages is sound. (I'm one of them so I may be biased.) I'm interested in getting the most out of the Evo as a daily driver. Maybe one day I'll want to fill up with race gas and take a spin around the track, but for the time being that just isn't practical. Maybe there really would be merrit to the idea of have two project cars, one as an all-out show stopper (aka, competition silencer) and another as the street warrior. Either way I will have fun reading the results.
newevo8, rather than me run down the upgrade path here, please visit our website and check it out. Everything we have done is listed there with prices.
Thanks,
David Buschur
www.buschurracing.com
Thanks,
David Buschur
Originally Posted by davidbuschur
I guess it is a little confusing.
As for how high you can rev. I don't know what Boost Solutions is doing for a valvetrain. We have taken the stock EVO stuff to 8,000 rpm. To be honest I think the springs are part of the problem with the car holding boost, they are just weak.
David Buschur
David Buschur
Tom
The turbo upgrades make more CFM which keep the boost higher as the engine stays full.
David Buschur
David Buschur
David Buschur
David Buschur
Originally Posted by Soon2BEVO
David, Ive been wondering why exactly in my 1G I could hold 23psi on my Big 16G to redline...
I think, I didn't go back and look, but somewhere in this I said something about how we use to port the heads compared to now.
At one time we basically hogged the port out as large as we could. This made for some great numbers to advertise at high lift. I figured the turbo was going to be pushing the air in anyway and the larger port was best.
I was told by the guy that owns the flow bench I was wrong. I then started experimenting with different port work and found something that actually flowed well in the area where our cams work.
I then took this head and put it on the race car. Well, he was correct. The power overall was improved across the entire curve.
Ever since this time we re-visit the flow bench from time to time to try a new idea or something we heard about.
The EVO head I used all we have learned up to now and am just amazed at what we have gotten it to flow.
The head work is now ready and anyone that needs to have a head done can send it in.
David Buschur
David Buschur
Flowing this head and advertising a flow number at .500 lift is useless. The biggest cam we run and most of you will ever run is only around .420 lift. Porting one of these heads to flow from 0-.420 lift is alot different than porting it to flow from .400 and up. We have learned to concentrate on nothing over .450, it does nothing for performance.
While it is longwided and potentially confusing to some enthusiasts, I wouldn't say the information is useless.
You say every flowbench reads different. I just want to clarify that the only reason this happens is because of the non-calibration and wear on the bench. Properly sealed, properly sized, cut and calibrated SEOs or calibrated / replaced LFEs / sensors, properly maintained, flowbenches will read very close to each other, flowing the same head. This is especially so if flowbenches are placed in large enough climate controlled rooms with matching temperature and humidity.
Operator integrity plays a bigger part than above.
I agree with you when you say there need to be standards as there are in the domestic head market. Flow listed at multiple lift points in tenths of an inch increments, at standard test pressures, and listing port entry or exit (radius, pipe, etc.)
Cheers
We use oversize valves in the heads. The springs/retainers, did they help? I am confused by the question. Did they help what?
David Buschur
David Buschur
Lightsaber
May 28, 2016 05:57 PM
KozmicMotorSpts
Nov 5, 2012 12:59 PM
downforceinc
Evo 'For Sale' Engine Internals and Drivetrain
21
Jul 8, 2012 09:17 PM
