Would oil cause valve knock
Old May 19, 2011, 11:16 PM
ILoveAWD's Avatar
i would just like to know if putting thicker oil in my evo would cause it to have lifer knock or valve knock at all? please correct me if i am wrong or stated anything wrong in the question that i have asked.
Old May 20, 2011, 05:12 AM
ILoveAWD's Avatar
someone? anyone?
Old May 20, 2011, 05:13 AM
ILoveAWD's Avatar
i was just wondering.
Old May 20, 2011, 06:10 AM
binky's Avatar
What's your reason for using heavier oil? What are your mods? What kind of oil are you using?
-Bink
Old May 20, 2011, 08:38 AM
ILoveAWD's Avatar
the oil used was rotella t6 it is a full synthetic oil and the weight was a 5-4o was that too much. sorry i wasn't detailed in my first post but the car is tock for the most part that i know of just got it on tuesday and is trying to get it right i don't know what was done or is done to it but i do know that it was hit and was not registered to the car fax or whatever.
Old May 20, 2011, 09:07 AM
barneyb's Avatar
There are some owners with lifter noise who have attributed the problem to switching to heavier oil or heavier oil of a particular brand. The trouble is, there is usually a following post were another owner states they are using the same oil without problem.
Search some of the oil threads - there's a ton of them on here. Then you can be as confused as I am.
Old May 20, 2011, 06:54 PM
ILoveAWD's Avatar
lol thanks for the advice man
Old May 20, 2011, 08:19 PM
sparky's Avatar
If you have lifter tick at idle. then try Mobil1 0W-40. This worked for me.
Old May 25, 2011, 11:10 AM
walker992's Avatar
yes i had the same problem and switched to amsoil and it quit
Old May 25, 2011, 12:57 PM
btmboards's Avatar
I am running Mobil1 0-40 and am not a fan. I get more engine noise with this that any other oil I have ran. I will be changing it this weekend and probobly going to try an AMS OIL.
You are going to find that lifter tick comes and goes with oil quality not consistancy. I Used to run far thicker oil than that in my VIII which got rid of all ticks and nocks but Im currently working my way through the different oils for something new on the XI
haxr303
Sep 28, 2015 07:54 PM
EvoIXPilot
Feb 11, 2013 07:20 AM
Robertv34
24
Sep 7, 2011 07:23 AM
xpro
Jun 3, 2008 09:25 PM
SoCalRedLine
Apr 11, 2008 10:39 AM
Quick Reply: Would oil cause valve knock
