evo 8 problem need info
Old May 28, 2011 | 07:12 AM
master R's Avatar
last night my upper inter cooler pipe pop off from my intake, the car stop, i check under neet the car and the exhaust was red hot.
i drove the car 500 m at 1500 rpm 5 miles/per hours on the side of the highway stop and replace the pipe at the intake.
now i noticed a lack of boost pressure , can only boost 12- 14psi ....
what you think guy 's turbo is going away ? hope have not damage my engine too
anyone happened to you ?
also what is the grind sound when i release the clutch on gear or neutral ....sounds gone away whent i push the clutch ?clutch bearing ?
Old May 28, 2011 | 07:25 AM
SEEnoEVO's Avatar
Did you check for a boost leak? That would be the first place to start.
Old May 28, 2011 | 07:31 AM
master R's Avatar
fast check .... i will double check today ......
Old May 28, 2011 | 07:35 AM
grillpt's Avatar
Were you beating on the car a lot before the pipe blew off?
Make sure your vacuum line didn't pop off your fuel pressure regulator, that can cause the motor to go lean and in turn will make your exhaust glow red.
Check for boost leaks, make sure all the piping is tight.
Sounds like your throw-out bearing is making some noise, not too much cause for concern. I would worry if continues to get louder and louder, then you may be looking at a clutch.
Old May 28, 2011 | 10:49 PM
06RedRalli's Avatar
Maybe the car went into limp mode..try unhooking the battery for a few minutes.
Old May 30, 2011 | 05:22 PM
master R's Avatar
All the piping check ! seems to be ok
i try to by pass my manual boost controller with the plastic fitting ....a reach 10 psi .....put back my mbc (turn the knob at full capacity ) still pushing 15 psi not much ....
i can hear the motor running louder and i defenitly have a loss of power .... but pass 7000rpm i can barely hear the turbo
i am curious why suddenly my intake piping blow out from my intake since a don't over boost ... what can do that beside a overboost ....
the car seems to run nice beside that ..... i try to disconnect de battery but not much difference
maybe ready to swap for a evo 9 turbo ?
by the way i have a evo 8 2003 with 98 000miles .....purchased 6 month ago
Old May 31, 2011 | 03:27 AM
MR. EVO MR's Avatar
u have a leak, use t-bolt clamps, hairspray. before you boost lower the mbc
Old Jun 14, 2011 | 05:23 PM
master R's Avatar
ok up date !
no leaks found !
compression test 160 160 160 160 pretty good for 98 000 miles
change the mbc and the bov swap for a evo 9 oem brand new .
everythings seems to be normal except i can 't boost more then 12 -14 psi
i noticed when i release the gaz pedal to shift i lost instantly all the pressure .... and today in the traffic my idle jump to 850 rpm to 1350 rpm ... and stay there , i put the a/c on and it drop at 1000 rpm normal.
then my boost pressure gage indicated 0 vacumm .... re start the car and show 19 vacum like before ...
i have done a motor shampoog one week before a blew the hose from my intake ..... and had my boost problem
could it be a sensor problem ?
i'm pretty lost now ..... should i go for a evo 9 turbo new for 899 $ here in canada
Old Jun 14, 2011 | 05:35 PM
master R's Avatar
well i was on fift gear at 140 miles ....
Old Jun 14, 2011 | 09:46 PM
dastallion951's Avatar
then what it sounds like is you either have a vacuum hose popped off, more then likely its your vacuum line where the boost gauge ties into...or one of the lines are cut or somethin, like someone posted earlier, nice little trick spray hairspray on each pipe where the coupler is where the clamp goes, then tighten each down till you feel some resistance, just if your on stock clamps make sure u dont use a screwdriver but use sockets.
Old Jun 14, 2011 | 10:08 PM
maevo8's Avatar
Have u checked the vacum line that goes to your wastegate?
Old Jun 16, 2011 | 10:53 AM
master R's Avatar
yes !
Old Jun 17, 2011 | 09:11 AM
did u attempt to check the vacuum lines behind the throttle body for the egr valve...??
Old Jun 17, 2011 | 05:14 PM
master R's Avatar
problem solved ! catalityc converter failure ! the one i have it was composed of metal inside ... not ceramic so that why i never heard any noise from it !
when i said it came glow red !!! well it was the problem !
Old Jun 17, 2011 | 05:41 PM
awd_ole's Avatar
check ur couplers i had the same problem...make sure they are not ripped
maxspeed96ct
Sep 29, 2016 06:53 AM
Btaylor36
Lancer Tranny/Drivetrain Tech
Aug 27, 2015 06:03 PM
Street gear
Nov 6, 2013 12:54 PM
evo_RS
Jul 14, 2010 04:15 PM
Tek3Evo
Aug 14, 2008 01:25 PM
