exedy twin HELP: cant get in gear when the car is on, and its dragging
Old Jun 4, 2011 | 10:07 PM
  #31
Pirana's Avatar
I just went thru this same problem...bought a new clutch thinking that was my problem...took out the transmission and found out my clip was warped and out of place, not letting full movement of the release bearing. $2000 mistake, since I had bought a new clutch already. The clip is $30 from STM.
Had also a slight vibration on the pedal...it turned out the clip was putting uneven pressure on the bearing which was in turn warping the bearing "install tube" and making it vibrate.
Final answer, trans needs to come out.
Old Jun 11, 2011 | 10:44 AM
  #32
Evoleader88's Avatar
so i got my tran pulled out to day and found out that the middle plate ( intermediate plate i think that what its called) is warpped. ill post pic later
Old Jun 11, 2011 | 11:07 AM
  #33
4RETECH's Avatar
Glad you found it. Now just get a new plate and put that baby back on the road.
Old Jun 12, 2011 | 10:17 AM
  #34
cumminsracer14's Avatar
Mine did the same thing but was the pressure plate.
Old Jun 12, 2011 | 09:13 PM
  #35
Old Jul 13, 2011 | 05:37 PM
  #36
sawgunner06's Avatar
I am running an EXEDY stage 2 right now having this problem...a month after my cams install....I have a stage 4 in my garage.... So what do you all think... Just pop the stage 4 in and hope for the best... only 53k miles on the car
Old Jul 21, 2011 | 02:19 AM
  #37
evoballer's Avatar
Im having a clutch drag issue and i bled my clutch line lots of times so its not the air problem. i had adjusted my pedal up and down many times so its not adjustment problem. i checked all my linkage, it all setup right so not linkage problem. How do i know id it is a master cylinder problem?
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
Havoc86
Lancer Troubleshooting
Mar 5, 2013 06:31 PM
RawrImAMonster
20
Jan 4, 2013 09:24 AM
EvoDan2004
Apr 5, 2007 05:47 PM
EVO32570
Dec 26, 2004 03:31 PM
