Help! Best turbo/motor set-up for Time Attack and Road Racing?
Old Aug 2, 2011, 10:52 AM
  #76
mrfred's Avatar
Originally Posted by Kidloco51
Wow this thread is still going? A lot has happened since I started this thread on my end.
So here are updates on my end:
I decided to build my stock block so I sent my block off to MA performance for a short block build. Specs on the new block:
9:1 Manley Pistons
Manley 156mm H-beam Long-Rods
ARP Main, connecting, head bolts
Balance shaft delete on block
I ordered a MA EF3 turbo aswell.
My head goes to the machine shop this week, Port polish and GSC S2 cams and beehives.
I also got a Full Race Pro- Stock manifold and a ETS 3.5 Intercooler.
I think my power goals are well within reach now. Thoughts?
Quite a departure from the original plan on the turbo. Hope it spools like you want. Good that you went with a built bottom end. Didn't follow your threads too closely - are you going to ditch the 6-speed or reinforce it?
Old Aug 2, 2011, 11:06 AM
  #77
TxEvo8's Avatar
I have six jugs for corn, I fill up, then bring 30 gallons to the track and I can make it the whole weekend. Not a pain at all.
Old Aug 2, 2011, 11:08 AM
  #78
TxEvo8's Avatar
Jarrod mentioned the TAK335r from CBRD, I actually have one of those turbos that I'm selling. Please let me know if you are interested.
Old Aug 2, 2011, 11:09 AM
  #79
blackenedwings's Avatar
Awesome. I'm sold on corn now, I'm so excited I'm finding it hard to concentrate on work.
Old Aug 2, 2011, 12:00 PM
  #80
Kidloco51's Avatar
Yeah I am curious to see how the turbo works out for me.
I swapped out my 6 speed earlier this year. I took the 6 speed out in working order and sold it. I ran a cooler on the tranny which I know for a fact improved the life of the thing (added almost 1 more quart of fluid.) I am currently running a pump/cooler set up on a stock 5 speed.
Old Aug 2, 2011, 12:43 PM
  #81
justboosted02's Avatar
my car basically meets the goals you set
2.3L/ full-race manifold with a BW s200sx. im sure with one of the newer gen turbos (EFR, GTX) it would make more and spool faster
makes around 450WHP on a dyno dynamics at ~23 psi on 93 octane. hits full boost ~3900.
as for tubular manifolds and roadracing; if you buy a quality manifold, you dont have to worry
Old Aug 2, 2011, 04:41 PM
  #82
Kidloco51's Avatar
I bought a Full Race manifold. That thing is stout I am not afraid of it cracking, it does put off a lot of excess heat though (need to get it jet-coated etc.)
Old Aug 3, 2011, 01:43 PM
  #83
you have any info/pics on how you put the cooler on the 5spd?
Old Aug 3, 2011, 04:00 PM
  #84
Kidloco51's Avatar
Here is the build thread on my old 6 speed. only thing that changes on the 5 speed is a an fitting on the drain plug or fill pug ( I forgot)
https://www.evolutionm.net/forums/dr...y-6-speed.html
evodave
Jan 25, 2009 04:58 PM
ambystom01
Jan 20, 2008 01:35 PM
Vivid Racing
Evo 'For Sale' Suspension / Brakes / Handling
May 13, 2005 09:45 AM
Vivid Racing
Jan 11, 2004 09:24 PM
Quick Reply: Help! Best turbo/motor set-up for Time Attack and Road Racing?
