slow spool - bad BCS or WG
Old Jun 12, 2011 | 07:02 PM
Locdizzel's Avatar
I was reading through the forum and found the stock 03 evos should be hitting 19 psi at 3500 rpm and taper to 16 psi by 6500 rpm, i've never hit 19 psi at all since I got the car (bone stock, unmodified with 45k) i max at ~15psi
since the mods i've added and still untuned still had same spool characteristics, last week i added short uicp and a licp and got a tad bit faster spool but still not getting up to 19 psi. I searched and found it could be the stock bcs and removed the line to the wastegate and boosted to infinity in 3rd gear (stopped at about 20 psi)
so is my bcs bad or wastegate, or did i read wrong.
Old Jun 12, 2011 | 07:12 PM
Mikey's RS's Avatar
Is the pill still in the line? I had a car that it was missing and had similar symptoms as you
Old Jun 12, 2011 | 07:27 PM
Locdizzel's Avatar
yea last time i check they were both there because i accidentally took out one of the lines with the pill and was hitting 10 psi max but put it back, but i will look again when it cools off. are both pills the same size?
Old Jun 12, 2011 | 07:49 PM
localtoys73's Avatar
why havent you had the car tuned?
Old Jun 12, 2011 | 07:56 PM
Locdizzel's Avatar
had a kid so funds were on hold and needed to finish getting the rest of the parts but im getting tuned around in a month or 2
Old Jun 12, 2011 | 08:00 PM
You should do a boost leak check.
I think the tune will fix allot of your issues. There are a few good e tune guys on the forums if you are looking for a cheaper route. That would be my next step in the process after the boost leak test.
Old Jun 12, 2011 | 08:17 PM
Locdizzel's Avatar
did many boost leaks replaced TB shaft seals and no leaks after that.
found the both pills
Old Jun 13, 2011 | 04:50 AM
sparky's Avatar
Install a MBC and also increase WG spring pressure up to 17 PSI.
Old Jun 13, 2011 | 06:00 AM
Locdizzel's Avatar
yea that was going to be my next step, if I cant find a decent one on here im most likely going to run an ebay voodoo one for the next month because i will be getting tuned for ecu controlled boost.
Old Jun 13, 2011 | 02:00 PM
Ryuartz's Avatar
Mine does similar thing after car went back to stock. Max boost 16 and tapers 14. I had big boost leak from TB seal and Fuel injectors but after fix, still does same thing. I am thinking borrow boost gauge from friend. Mine could be off. What should do next if that doesnt help? Check exhaust leak? Let me know how it goes.
Old Jun 13, 2011 | 02:28 PM
GrnEVO's Avatar
+1 on both. Get ahold of Tom at VRSF (tcompusa on the forum) he offers great customer service and a REALLY affordable rate. Just gotta have some thick skin if you're trying to learn during the process
Mohannad
Cobb AccessPORT
Jul 11, 2020 05:40 PM
Casey Robertson
Jan 29, 2016 03:59 PM
HornstarBU
Oct 20, 2011 09:03 PM
project_skyline
Jul 17, 2009 05:30 AM
supersal
May 16, 2008 12:52 AM
