Advice please, car wont stay running when warm
Old Jun 22, 2011 | 12:31 PM
F0RSAKEN's Avatar
Helping a friend out with his car, and it seems that about a week ago it started dying randomly, and having difficulty restarting.
I believe it only does this (or at least more often) once the car is up to full temp. as it starts and runs perfect when cold.
Plugs were replaced, and a new set of coils were tested, to rule out the ignition, or that portion of it, but what else could be causing something like this? I ran the car with EvoScan on, and the ECT sensor is returning a good value, and constant, so it isn't that, the o2 sensor seems to be responding well, the tps and iscv seem to be working just fine, where else should I look? Thanks.
Old Jun 22, 2011 | 01:24 PM
andrewzaragoza's Avatar
clean out your maf and iscv if you haven't. also make sure you check if you have a boost leak.
Old Jun 22, 2011 | 02:02 PM
sktng22's Avatar
did you try only running it on open loop?
Old Jun 22, 2011 | 02:23 PM
F0RSAKEN's Avatar
Er, shoulda added some stuff: It's an SD car, so no MAF.
And no, haven't tried the open loop yet.
Old Jun 22, 2011 | 02:57 PM
sktng22's Avatar
is the map sensor all good?
Old Jun 22, 2011 | 03:45 PM
Ryan.Kauz's Avatar
I am the poor soul with the broken car.
Map sensor is one of the items we will swap over from FORESAKEN's running vehicle to mine for testing.
Old Jun 22, 2011 | 04:11 PM
sktng22's Avatar
hmmm what where the AFR's looking like when this happens? did you check the fuel pump at all? its gotta be something stupid
Old Jun 23, 2011 | 08:13 AM
F0RSAKEN's Avatar
The owner doesn't feel that gauges are necessary, so AFR is out
Old Jun 23, 2011 | 09:31 AM
Ryan.Kauz's Avatar
No, the owner doesnt want a ton of clutter on a DD, with gauges blocking the purdy views of Seattle raindrops or the speedo/Taco.
Old Jun 27, 2011 | 11:21 AM
Ryan.Kauz's Avatar
Andrew felt making a new thread would be more accurate than updating his first thread....
Please take a look at the log posted here and if you have any insight I would appreciate your input!
https://www.evolutionm.net/forums/ev...tarvation.html
tsidrift1
May 19, 2016 06:19 PM
hooliganSKATE
Dec 24, 2015 01:57 PM
user 629782012
Canadian Forum
16
Feb 2, 2012 12:11 PM
05mazdarx8
13
Dec 17, 2008 06:15 PM
jesterEVO
Jan 28, 2005 01:18 PM
