Setup suggestions vets?
Old Aug 1, 2011 | 10:20 AM
  #61
projektevo9's Avatar
Sounds good, yes I'm planning on running the fp3586 I'm talking to Chad @ CBRD about my setup as well now I'm assuming that the fp 3586 isn't considered a stock frame turbo? Thanks for answering all my questions guys very helpful!
Old Aug 5, 2011 | 10:26 AM
  #62
fre's Avatar
fre
FP3586 is definitely not a stock frame turbo. You wouldn't want it to be with how much it flows. I am even tentative to try and mount my .63 hotside to one as I am assuming surge will suck ballz even more so then it already does with my regular 3582.
Old Aug 5, 2011 | 11:19 AM
  #63
mt057's Avatar
What boost level are you running when you surge? It is a normal 3582 not a HTA?
Old Aug 6, 2011 | 07:33 PM
  #64
fre's Avatar
fre
I run 32-33psi and in 4th gear even sometimes 3rd and above it will surge. It is non-HTA, but that is pretty normal for a large turbo on a small engine, especially since I have no head work and not too aggressive cams (HKS 272). Not enough flow in the engine at lower rpms to use all the air flow the turbo can produce.
mdyasar
Jul 27, 2014 06:51 PM
Leekitchens1234
Jun 14, 2013 06:57 PM
evo8grl
For Sale - Cars For Sale
50
Aug 13, 2009 01:16 PM
crimepays252
Apr 8, 2008 08:22 AM
Nomad4g63
31
Nov 26, 2007 10:46 AM
