Strange Clutch Problem
Old Jul 14, 2011 | 11:24 AM
evascst's Avatar
So I have searched and found threads with similar issues but none of them where ever resolved.
About a week ago I had my clutch installed and after two days of driving im now locked out of every gear upon start up and anytime I sit in neutral.
The strange things are: if I start the car in gear and drive off it shifts like a dream, if i never let off the clutch pedal it shifts like a dream, if after sitting and I get locked out all I have to do is rev the engine between 3k and 4k and it will glide in like butter and the strangest of them all is if the A/C is on, the car shifts after sitting but just a little notchy.
Anyone have any ideas as to why it is like this?
Old Jul 15, 2011 | 06:03 AM
evascst's Avatar
No one has any ideas?
Old Jul 15, 2011 | 06:23 AM
WHTEVO's Avatar
I would start by adjusting your clutch pedal/ rod. It sounds like it is probably dragging. Good luck.
Aaron
Old Jul 15, 2011 | 10:03 AM
05blue8's Avatar
http://www.jackstransmissions.com/pa...-tech-articles
Do this
Old Jul 15, 2011 | 10:52 AM
gkania's Avatar
Clutch shifter linkage in the engine bay
Old Jul 15, 2011 | 11:01 AM
ViNZx_xD's Avatar
Well, my clutch starting to act weird lately too. When I press it all the way to the end, you will hear a click sound...I HATE IT!!!
Old Jul 15, 2011 | 01:41 PM
evascst's Avatar
what do you mean by the clutch shifter linkage? what am i looking for because i can get in there and move them through the gears by hand and its smooth as can be.
ive adjusted the pedal exactly how in the video for the dsm's
i even went as far as bleeding the system and pushing the slave cyl rod back to get as much air out as possible befor retightening.
Old Jul 16, 2011 | 08:57 AM
evascst's Avatar
any one else have any ideas?
Old Jul 16, 2011 | 09:12 AM
AreSTG's Avatar
air in the line maybe? try bleeding it if you know how.
Old Jul 16, 2011 | 12:55 PM
evascst's Avatar
Bled several times now, even pushed the rod on the slave back in to get any extra air out.
this is annoying. after driving for a hour or so it shifts better but notchy. anyone think the fluids may be to think or something? redline mt90 is whats in the trans
Old Jul 25, 2011 | 01:19 PM
evascst's Avatar
Now im getting locked in gear if i deaccel to low rpms. if i blip the gas it will release the gear.
anyone have anymore insight on what could be the problem?
Old Jul 25, 2011 | 01:28 PM
PKEVO8's Avatar
what kind of clutch did you install?
Old Jul 25, 2011 | 01:41 PM
evascst's Avatar
Clutchmasters stage 3 clutch with gruppe-s flywheel. i had the same clutch befor with no problem at all.
Thomas Estlick
May 14, 2016 10:19 AM
BGM3
Dec 7, 2010 01:41 PM
delongedoug
May 21, 2010 04:20 PM
bostonhatcher
Jul 19, 2009 06:41 AM
Bitnode
Lancer Engine Tech
Mar 30, 2004 10:49 AM
