Reusing Exedy Twin
Old Jul 18, 2011 | 05:54 PM
Babs's Avatar
Reusing Exedy Twin
I just recently picked up an Exedy twin with fairly good meat left on the plates and I'm thinking of just running them until they won't hold anymore. Reason being is that I'll be going big turbo in the near future, but not now, and I'll just convert to a triple so it's a brand new clutch with a brand new turbo.
Anyways...if I just reused the clutch as is, without replacing any plates or anything, would I need to resurface the flywheel or do anything or just throw it in there? I know you need to resurface for new friction discs but wasn't sure if you did or not with the same plates.
Thanks!
Old Jul 18, 2011 | 06:03 PM
milford's Avatar
the answer really depends on the condition of the flywheel.
Old Jul 18, 2011 | 06:49 PM
RSMike's Avatar
i would disagree.
i would say it depends on how much the top pressure plate has warped, and if it has then what is the top friction plate wear like.
Old Jul 18, 2011 | 08:43 PM
Babs's Avatar
So basically just have a machine shop inspect it?
Old Jul 18, 2011 | 08:45 PM
xRoguex's Avatar
theres a thread either on here, or highboost that gives the specs of a brand new, and compeltely worn out twin.. so you know where your at...
Old Jul 19, 2011 | 10:43 AM
EAVWIDL's Avatar
would not recommend that. alot of work to find out it wont go in gear. then u got to pull it back out
Old Jul 20, 2011 | 06:29 AM
05blue8's Avatar
Yep, what he said. If any plate (pressure, disc, intermediate, flywheel) is worn, it will slip...I'm learning that the hard way *sigh*
Old Jul 20, 2011 | 07:38 AM
TopSpeed's Avatar
Replacement clutch disks are fairly cheap for the Exedy twin..
-Josh
Old Jul 22, 2011 | 06:28 PM
roostinds's Avatar
I would just replace disk as well. Have flywheel inspected. You don't want to do that install twice. You will kick your self in the butt for not replacing. If clutch in car isn't going bad, save up for replacements and have a fresh new clutch in car when your ready.
Old Jul 22, 2011 | 06:52 PM
xRoguex's Avatar
http://highboostforum.com/forum/show...D-Cerametallic
TeachersEvo
Jul 11, 2016 10:51 AM
mr.almeida
23
Jan 17, 2016 01:47 PM
RSMike
Dec 26, 2011 08:51 PM
krazykorean84
Feb 25, 2011 11:25 AM
idriveawhiteevo
16
Jan 2, 2005 11:35 AM
