Reflashed ECU and black grit?
Old Jan 2, 2004 | 01:06 PM
  #46
DynoFlash's Avatar
Originally posted by GottaGoFaster
Al?
Give me a call - lets keep this thread on the soot !
Old Jan 2, 2004 | 01:09 PM
  #47
DynoFlash's Avatar
One more thought on this subject - - - - ANY one getting a through the mail flash - the idea is to make your car smoother, faster, "feel" better and run a bit leaner - - - Its NOT going to be perfect through the mail - - when we custom tune thyere is always a lot of work to dial it in perfectly on an individual car - the point is the mail tune is a LOT better than stock
For more details . . . read the below quote
Old Jan 2, 2004 | 01:51 PM
  #48
silvrevo's Avatar
Thanks everyone involved....I feel better about this now.
Maybe if 10.8 10.9 could be done throughout, I might mail it back in? A tune in person would be ideal, but might not happen.
When you tune in person on a dyno, what numbers do you want to be at, and not go over?
Thanks again .......... maybe this will be useful others as well?
Sorry if I was a pain in your *** Al.
Old Jan 2, 2004 | 02:12 PM
  #49
sr20det91's Avatar
Mos Def. My Vishnu exhaust looks worse than that with no engine management at all.
Like the others said. It just looks worse than it was with your shiny tip. Your A/F chart looks pretty damn safe to me. Get a custom tune with Al to lean it out a bit more and you will pick up some HP and have less of a pollution problem.
Old Jan 2, 2004 | 02:32 PM
  #50
DynoFlash's Avatar
On a custom tune - I tune them between 10.9 and 11.1 / 1 on my motec wideband
With the through the mail flashes I shoot for 10.6 - 10.8 /a as the target with 92 octane - - yours looks OK excpet on the very top end its seems a little rich which is OK
What would alarm me is seeing a 12.0 / 1 a/f on a pump gas car - (as we have seen with other tuners) - this would be not only out of range - BUT DANGEROUS and detonating on pump ga sand riding the knock sensor.
The reason why we shoot on the richer side is so we can avoid the ocassional car that would run too lean. Basically 90 % of the through the mail cars will be a bit too lean so that the 10% of the lean running cars will still be rich enough - if that makes any sense
Its not ideal - but we have been able to get a lot smoother power band, a lot better spool up and top end power and great "feel" while riasing the peak power by 15 - 20 whp - ALL while keeping the a/f in TOTALY SAFE levels and maintaining very good long term durability - this is our mission
WE ARE NOT about trying to squeeze out an extra 3 - 5 whp at the expense of riding the knock sensor and having an rough power band and unsafe tune
Old Jan 2, 2004 | 02:50 PM
  #51
Michael A's Avatar
silvrevo......the photo of your exhaust tip looks pretty normal to me. In fact I would say that my stock EVO might be a little dirtier.
Old Jan 2, 2004 | 02:51 PM
  #52
silvrevo's Avatar
Allen,
Sounds good
Now if anyone else has a question about a black exhaust tip, you can point them to this nice long thread.
I will keep an eye opened if your in my area for a dynotune.
Thanks.
hkopenep074714
Oct 7, 2008 02:47 AM
thebigt
Lancer Engine Tech
May 31, 2008 12:23 AM
tsherriff
Jan 31, 2007 04:41 PM
rodrig.diaz3
Nov 10, 2006 06:37 AM
