need help with ss lines
Old Aug 4, 2011 | 06:45 PM
VrMPSHHH's Avatar
so my clutch is acting up, grinding in 1st etc. and being just noisy...i did some investigating and found a braided line not attached to anything right above the tranny, not wet or anything. is that a clutch line?? i think i may need fluid if thats the case..plz help
Old Aug 4, 2011 | 06:53 PM
sktng22's Avatar
wait what. the clutch line isnt attached? were does the ss line goto? and did you buy the car new? because stock they come with a rubber line unless changed to a ss line
Old Aug 4, 2011 | 07:10 PM
VrMPSHHH's Avatar
no no its a 2003 and i bought it recently..well i have the one ss line going from the release cylinder down to a hole in the tranny and there is a shorter line coming from that same hole that is not attached to anything...this may be my problem
Old Aug 4, 2011 | 07:26 PM
Evoryder's Avatar
Picture please. This would be a first.
You will need to connect the cable accordingly and bleed clutch system.
Old Aug 4, 2011 | 07:47 PM
VrMPSHHH's Avatar
here are some pictures of what im talking about, it has a hydraulic release bearing due to it being a twin disk but should i have an open line??
Attached Thumbnails need help with ss lines-103_1024.jpg   need help with ss lines-103_1023.jpg   need help with ss lines-103_1020.jpg   need help with ss lines-103_1017.jpg
Old Aug 4, 2011 | 08:24 PM
Evoryder's Avatar
I have an exedy twin, it still connects. That line should lead from master to slave cylinder.
Old Aug 4, 2011 | 08:28 PM
4whlbst's Avatar
That's the bleeder line for your hydraulic throw out bearing. Notice how the end of it looks just like the bleeder nipple on a brake line.
Old Aug 4, 2011 | 08:38 PM
Evoryder's Avatar
Oh ok. He has the push style tob.
Old Aug 4, 2011 | 08:52 PM
VrMPSHHH's Avatar
oh ok, so how would i go about bleeding that? my clutch is making a horrible grind im just wondering if fluid is my problem
Ralliart09er
Jan 10, 2015 08:03 AM
nightmarepr
Jun 20, 2013 09:07 PM
hachansoo0413
Mar 18, 2013 08:41 AM
tkklemann
Jul 13, 2007 07:05 PM
Lowness
Sep 2, 2004 06:24 PM
