Clutch line
Old May 12, 2013 | 06:52 PM
nightmarepr's Avatar
Clutch line
Guys I want to buy a clutch line that is directly to the slave or bypass the modulator as in a direct line from the master to the slave cylinder, I see there are a few in eBay SS clutch line but I don’t know what are the specs I need for the lancer ralliart 2006. if any here know and can tell me what I need to buy thanks in advance.
Old May 12, 2013 | 08:30 PM
CrAnSwIcK's Avatar
are you going for looks? cause you can just use brake lines.
Old May 13, 2013 | 03:25 PM
beautifulpunk's Avatar
You can buy one from STM..they have a master to slave clutch line for the Evo..they are a direct bolt on for our cars..they are like $55
Old May 13, 2013 | 05:03 PM
juanharu4913's Avatar
Evo VIII ss line should fit from what I remember, the only problem is it is in a wierd spot to get to (The upper connect to the brake line reservoir). But in the end it really is just a misc steel hose like Cranswick said.
Old May 13, 2013 | 05:36 PM
yea, iam looking more by performance and quality i found this thank guys check it out http://www.streettunedmotorsports.co...r_to_slave.htm
it says it cost 5 dollars for PR you guys tell me if i should go with it
Old May 14, 2013 | 05:11 AM
CrAnSwIcK's Avatar
rigid hydraulic brake line wil perform the same...if you want shiny braided steel hose then spend the money, realistically you could get a 25 cent fitting to replace the modulator and that would give you the same result...
Old May 14, 2013 | 06:35 AM
lanzerralliart's Avatar
EvoM Super Moderator
Crans is on the money , and saving money. Or you could just gut the modulator for free.
Old May 16, 2013 | 05:09 AM
rzrxn's Avatar
hmmm...
i remember reading about this.
i wanted to get the RRM one but people advised that i shouldn't do it since it doesn't really do much.
read up on it here...
https://www.evolutionm.net/forums/04...er-bypass.html
lemme know what route you decide to take.
enjoy!
Old May 16, 2013 | 02:53 PM
RacerX-Ralliart's Avatar
Nobody remembers that you can run the line from the modulator to the slave bypassing it?
Old Jun 20, 2013 | 09:07 PM
Luckiesralliart's Avatar
Hello to OP. Im finishing up my own hard line that will replace the current hard line and modulator. I should have a finish product in a few days and will upload a pic so you can see what you think and if this is a route you would want to take. I'm only replacing this part first, once I make sure I like the feel I'm going to make one solid line all the way to the top clutch/brake cylinder (only issue is it needs to be able to flex some to allow for motor vibration), hope to post a pic soon.
STM Tuned
Evo 'For Sale' Engine Internals and Drivetrain
92
Oct 25, 2017 08:39 AM
evo1008
Sep 17, 2014 07:29 PM
J187SD
Jul 23, 2013 11:51 PM
hachansoo0413
Mar 18, 2013 08:41 AM
