Ryu's built motor thread (Sponsored by MAPerformance)
Old Nov 7, 2011 | 05:25 PM
  #91
RyuEvoIX's Avatar
I have the original aquamist hfs-1.
Old Nov 7, 2011 | 06:06 PM
  #92
wizzo 8's Avatar
I like the multiple nozzles but what if one gets clogged? How will you know?
Old Nov 7, 2011 | 06:26 PM
  #93
RyuEvoIX's Avatar
All Aquamist kits utilize a pre pump filter to insure there is never any foreign materials in the system to block flow. The in line filter is 100 microns and the in tank filter is 112 microns.
Old Nov 7, 2011 | 07:18 PM
  #94
wizzo 8's Avatar
Oh ok that makes sense.
Old Nov 10, 2011 | 06:13 AM
  #95
lillev23's Avatar
Nice to see you're still sticking with the meth Ryu. Hope the build works out well for you. Who will be handling the tuning?
Old Nov 10, 2011 | 07:49 AM
  #96
danameisoj's Avatar
it will be ryu tuned...
Old Nov 10, 2011 | 07:54 AM
  #97
RyuEvoIX's Avatar
Thanks Will, and that is correct. I'm handling all of the tuning.
Old Dec 8, 2011 | 08:32 AM
  #98
RyuEvoIX's Avatar
update:
I have finally completed the 1,000 mile break in on the motor and am nearly done with the pump gas tune on wastegate. I don't want to give out too much information until the tune is finalized, but the car has already broken the 550whp mark. MAP's motor is certainly exceeding my expectations. I can't wait to get the car back on meth.
Old Dec 8, 2011 | 08:47 AM
  #99
Mitsi7's Avatar
In for results
Old Dec 8, 2011 | 08:52 AM
  #100
Spec-Ops1's Avatar
Good luck Ryu, and don't get greedy with that meth tune
Old Dec 8, 2011 | 12:05 PM
  #101
RyuEvoIX's Avatar
Thanks Freddie. I see no reason to attempt to push the tune on the car at all. This setup is exceeding my expectations already on regular fuel and expected ignition timing. I originally was looking for 620-630whp with this setup on methanol, however in light of what I am seeing with the pump gas results so far, I believe 650-660whp will be achievable without pushing the envelope.
Old Dec 8, 2011 | 05:45 PM
  #102
Spec-Ops1's Avatar
Ryu, my cell number is in my sig, if you need to bounce any ideas off me feel free to hit me up...
Old Dec 8, 2011 | 06:41 PM
  #103
S13 Curtis's Avatar
I'm also pretty sure methanol has a higher oct rating then ethanol so he should be fine. Very nice meth set up btw. I might do one just like that.
Old Dec 8, 2011 | 06:48 PM
  #104
S13 Curtis's Avatar
You will def pass that mark if I did 610 on the stock block with methanol and 2 nozzles. I think you will be 700+
Old Dec 8, 2011 | 09:15 PM
  #105
localtoys73's Avatar
Congrats ryu hope to go for a ride in it soon
