Springs on TOB are backwards...what to do?
Old Sep 18, 2011 | 05:00 PM
Babs's Avatar
So I go through a **** ton of pain today, put a hole in my HKS intercooler, spend all day dropping the motor back in, putting the trans in, bolting everything up, getting the transfer case on, and all the mounts tightened. Now I come to find that the springs on the TOB arm are backwards.
Is there anything I can do without dropping anything out? If not, what is the absolutely EASIEST way to go about this?
Someone up there really hates me...
Old Sep 18, 2011 | 05:17 PM
Babs's Avatar
OK so they're not on backwards...but why is the throwout bearing springing back to the disengaged point? I'm trying to make sense of this because the slave cylinder should push on the clutch fork and thus disengage the clutch but the fork is already sprung to the disengaged point.
Any help?
Old Sep 18, 2011 | 05:30 PM
1UpMoto's Avatar
Did you push the throw out bearing into the wedge collar? take the slave cylinder off and push the fork towards where the slave cylinder mounts.
Old Sep 18, 2011 | 05:31 PM
Babs's Avatar
I did that but it just keeps returning to its normal sprung position.
Old Sep 18, 2011 | 05:34 PM
1UpMoto's Avatar
Do you have the spring clip in the pressure plate? Here is a pic of how it connects just for reference. https://www.evolutionm.net/forums/ev...t-bearing.html
Old Sep 18, 2011 | 05:45 PM
Babs's Avatar
Yes the wedge collar is in there...it's not latching on though.
Old Sep 18, 2011 | 06:55 PM
1UpMoto's Avatar
take a few pics from the inspection hole and post them up
Old Sep 19, 2011 | 07:09 AM
batty200's Avatar
You may have to take off the clutch slave to get the throw needed to get the TOB to engage the wedgecollar.
Old Sep 19, 2011 | 07:15 AM
Babs's Avatar
The slave is off and I'm throwing the arm all the way over and the TOB won't latch on to the wedge collar.
Looks like I have a couple hours work tearing it all back down.
fireroasted
13
Jan 13, 2016 04:35 PM
SQ2Evo
12
Feb 16, 2013 08:43 AM
jonzie04
May 22, 2012 12:41 AM
Oki Panoki
Driving Techniques
Dec 30, 2007 12:03 PM
kmcknight
Mar 9, 2007 03:25 PM
