Walbro 400LPH intank pump ? Anyone got any info
Honestly, when I purchased my injectors, I was debating cause I didn't wanna go low impedance with a big injector and I also didn't wanna spend $700-800 for 2000's for an injector that'd flow more than I'd ever need on pump fuel. When I saw you running a 9.0 on 1200's with race fuel, THAT is what sold me on 1250's. True story. Lol.
I've posted full flow results of the pumps, tested by DSport Magazine, it clearly shows the power potential of the pumps and such. I'm honestly too lazy to go dig it all up but the reality of it is if you have spent enough on your car to need a 400lph pump and you are debating on a couple hundred more for our double pumper that will make whatever power level you need……well you are a bit silly.
If you say the pump won't support the flow of my turbo, I'll just go with a double pumper. Not a big issue there. Just didn't know how much power the fuel pump would support on pump gas. Which is the reason I asked here on this post.
But where you have me confused is where you're saying my 1250's won't support the flow of my turbo when clearly you've ran a 9.0 on 1200's. I thought you were running a 3586 (or larger) turbo when you did it. Can you clarify please sir??? I will never touch E85 with my injectors.
When it comes to going fast and big power..... I think I would listen to DB.
As for him running 9's on those injectors I highly doubt that most people could duplicate those results.
I currently run a home made double pumper with 2 intake walbros...one of these pumps is acting up. They are both unrestricted walbros. Could I run the 400 with the other walbro 255? It looks like I could just clamp them together and plug it right in. Thanks for any input!
669awhp VD dynoyet rewire 450 (which it should be the same of the 400 just sealed)and 1650cc FIC not sure how reliable is the vd though they have a mustang dyno here in El Paso thinking on taking it there but is really a heart breaker dyno lol
Not at 570 whp yet, but hope to be there eventually. Currently around 535 whp. I can monitor rail pressure and can see net injector pressure falling off under high flow, high boost conditions due to the relief valve being triggered. My guess is that the new high pressure relief valve W450 at 14 V is good for maybe 575 whp before it can no longer sustain 3 bar rail pressure.
