Walbro 400LPH intank pump ? Anyone got any info
Old Dec 20, 2011 | 08:58 AM
  #346
acssa's Avatar
He said the ethanol one will becoming in Feb.
Old Dec 20, 2011 | 09:19 AM
  #347
mrfred's Avatar
Walbro says the 255 isn't ethanol compatible. they even did tests that showed much reduced lifetime, but it was in pure ethanol. seems to do fine in e85. mine's still going strong after three years in e85.
Old Dec 20, 2011 | 09:31 AM
  #348
David Buschur's Avatar
Yes, think for yourself......................3 months after all the debating and someone else figuring it out. Great advise.
Old Dec 20, 2011 | 09:44 AM
  #349
RyuEvoIX's Avatar
Still sore that you were proven wrong by myself and multiple competing companies? it'll be ok. Have a Merry Christmas.
Old Dec 20, 2011 | 09:47 AM
  #350
You didn't prove me wrong, you argued, talked trash and everything else. You told everyone you bought a pump months ago and were going to prove me wrong. Instead you ended up just a follower like always, waited until others figured it out and then came in here talking more trash.
Old Dec 20, 2011 | 09:56 AM
  #351
RyuEvoIX's Avatar
You trash talked to me in your initial response to my basic questions at the beginning of this thread. Pot meet Kettle. I am by no means a follower and my car/ accomplishments are a direct example of it. After all, my stock block fp red setup w/93oct+meth beat your fully built fp red project white on e85 by half a tenth. Who was I following with that one Dave? Then I went high 9s on a stock block in the only EVO over 3,000lbs . I'm a follower? try again buddy. No need to get your panties in a wad.
Old Dec 20, 2011 | 10:57 AM
  #352
Migsubishi's Avatar
Well said Ryu....
Old Dec 23, 2011 | 10:53 AM
  #353
wizzo 8's Avatar
Originally Posted by ChrisCarey
Be careful not to cut into the fuel pump plug (the black thing with the wire going to it), see below for the final product!
Here is what we ended up with:
What is the purpose of this black plug thing?
Old Dec 23, 2011 | 12:11 PM
  #354
drb's Avatar
drb
Good question, a "friend" told me that if you install it wrong (rotated 180 degrees) the fuel pump won't work!
Old Dec 27, 2011 | 07:27 AM
  #355
Jrod@Buschur's Avatar
For those interested.... https://www.evolutionm.net/forums/ev...check-out.html
Old Jan 9, 2012 | 04:38 PM
  #356
Tokuisport's Avatar
well here is a picture of mine i was able to use the bigger filter and stock retaining clip. took a little time trimming the stock retaining clip on the inside so it fit around the new pump and cut out the center section as well. i also beveled the inside of where the pump sits into so i could retain the tabs for the stock clip
and yes i know i accidently had the siphon tube on the outside when i took the pic but its all good now.
Old Jan 9, 2012 | 04:44 PM
  #357
wizzo 8's Avatar
Wow good job dude. Looks good
Old Jan 9, 2012 | 06:17 PM
  #358
mrfred's Avatar
Originally Posted by Tokuisport
Excellent.
Old Jan 9, 2012 | 10:07 PM
  #359
drb's Avatar
drb
There is definately more ways than one to retain the stock retaining clip.
Old Jan 9, 2012 | 11:28 PM
  #360
We cut and ground on the stock retainer too but in the end I thought it took away too much of the integrity and I was afraid it would fall off over time. The hose clamp I personally think is a better idea, but that is just my opinion.
