Walbro 400LPH intank pump ? Anyone got any info
Old Dec 12, 2011 | 04:35 PM
  #331
drb's Avatar
drb
Originally Posted by dtrackstar
So how much power is it good for on e85?
It's obviously going to depend on your tune, injectors, etc. I made 525 AWHP (VD Dynojet setting) on the modified Walbro 255 with 1450 cc FIC Bluemax injectors. I was running out of fuel so I have installed an adjustable FPR and the Walbro 400. It is definately running richer, but I have not been tuned for the Walbro 400 yet. Long way of saying that it should be good for well over 525 AWHP.
Dan (drb)
Old Dec 12, 2011 | 06:47 PM
  #332
wizzo 8's Avatar
My guess is around 600whp on a dynojet with E85 if you are lucky.
Old Dec 12, 2011 | 08:00 PM
  #333
drb's Avatar
drb
I'm guessing closer to 650whp on a dynojet & E85, but time will tell. My car won't make anywhere near even 600 hp so I'm pretty sure that the 400 is going to be a good choice for me.
Old Dec 12, 2011 | 08:07 PM
  #334
wizzo 8's Avatar
You might be right. Im shooting for 600-650whp on a Dynojet with E85. I was going to go with this pump but I changed my mind and am now going with a Double pumper just to be done with my fueling issues.
Old Dec 12, 2011 | 08:24 PM
  #335
drb's Avatar
drb
Here is an interesting read on the Walbro 400 in case you haven't seen it:
http://www.midwestevos.com/forums/showthread.php?t=8798
Old Dec 19, 2011 | 09:18 PM
  #336
RyuEvoIX's Avatar
Just wanted to report that I have finally purchased a Walbro 400lph pump. The pictures below illustrate another successful fuel pump housing modification. The housing modification took a total of 20 minutes giving more then enough clearance for the new pump to fit in comfortably. The installation of the assembly back into the gas tank went very smooth as well and presents zero clearance issues. In regards to the pumps performance, my personal experience with my car was seeing previous air/fuel ratios of 11.3 out the top to 10.3 air/fuel after the pump installation. If there's a lesson to be learned in this thread, it's to think for yourself. No matter who says "it can't be done", it can.
Old Dec 19, 2011 | 09:42 PM
  #337
Migsubishi's Avatar
Nice!!!!!!!!!!!!!!!
Old Dec 20, 2011 | 07:23 AM
  #338
mrfred's Avatar
Originally Posted by RyuEvoIX
... In regards to the pumps performance, my personal experience with my car was seeing previous air/fuel ratios of 11.3 out the top to 10.3 air/fuel after the pump installation. ...
Factory pump wiring or rewired?
Old Dec 20, 2011 | 07:26 AM
  #339
RyuEvoIX's Avatar
My 255 was rewired. This is a direct back to back comparison.
Old Dec 20, 2011 | 07:36 AM
  #340
RLLN247's Avatar
So you dont need the plastic bracket to hold the pump up or is it secured some other way.
Old Dec 20, 2011 | 07:43 AM
  #341
RyuEvoIX's Avatar
If you look closely behind the two rubber hoses you'll see a hose clamp around the pump to help give it extra support. It takes a really good tug to remove the pump when the grommet is seated in place with no other support. With the clamp lightly tightened down in place, the pump isn't going anywhere.
Old Dec 20, 2011 | 07:50 AM
  #342
mrfred's Avatar
what fpr?
Old Dec 20, 2011 | 07:51 AM
  #343
RyuEvoIX's Avatar
Fuel lab mini.
Old Dec 20, 2011 | 08:42 AM
  #344
acssa's Avatar
The local distributor told me the 400lph is not ethanol compatable!
Old Dec 20, 2011 | 08:51 AM
  #345
RyuEvoIX's Avatar
That is false.
