Walbro 400LPH intank pump ? Anyone got any info
Old Jun 27, 2013 | 07:32 PM
  #481
EvoDan2004's Avatar
Originally Posted by detroit pistins
MrFred,
can you explain what do u mean by "fuel filter in the pump carrier" ? are you referring to the sock type filter provided with the pump or an additional inline filter you're putting?
Also, I was under the impression that the stock wiring can do the job, is a rewire necessary?
Thanks in advance!
When you pull your stock hanger out you notice the "(" shaped thing. It's the big useless looking plastic part of the hanger. Inside that is another filter that can not be serviced.
Old Jun 27, 2013 | 07:33 PM
  #482
mrfred's Avatar
MrFred,
Thanks in advance!
There is a fuel filter embedded into the (white) fuel pump carrier. If you can find a picture online (earlier in this thread?), you'll see a big lobe on the pump carrier off to one side of the fuel pump. There's a fuel filter in there. I should post a picture some time of the one that I cut off.
A rewire is all about getting a close as possible to battery voltage at the pump. Factory fuel pump wiring might get to 90-95% if its in good condition. The best way to be sure max voltage is getting to the pump is a good rewire.
Old Jun 27, 2013 | 07:44 PM
  #483
detroit pistins's Avatar
Thanks alot guys! I am in the process of purchasing one and will share as many pics as I can when I install it.
This is probably better answered by walboro, but wonder if running 93 octane is ok on the e85 pump. especially for those traveling and may run dual maps at times.
Old Jun 27, 2013 | 07:51 PM
  #484
xXANCHORMONXx's Avatar
https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Heres my diy, hope it helps
Old Jun 27, 2013 | 08:26 PM
  #485
^thank you, very nice write up!
Old Oct 15, 2013 | 10:07 AM
  #486
Jeff_Jeske's Avatar
So what is the best single pump solution for a 500whp E85 powered EVO9?
Is an AFPR required or not?
Old Oct 15, 2013 | 10:10 AM
  #487
mrfred's Avatar
If the fuel pump wiring is in good shape, I think the pump is good enough for 500 whp on stock wiring and stock fpr.
EDIT: I should add that I think it will be necessary to drill out the siphon hole slightly, and the the table that sets the transition to full voltage for the fuel pump should be to higher load values than stock.
Old Oct 15, 2013 | 11:34 AM
  #488
Jeff_Jeske's Avatar
But which specific pump.... ive been seeing nomenclature of 400, 416 and even 450.
Old Oct 15, 2013 | 12:09 PM
  #489
mrfred's Avatar
F90000267 - This is the E85 compatible pump. There is only one e85 compatible version, but people have used 400, 416, 450, 465 to describe it.
Old Nov 4, 2013 | 06:55 AM
  #490
tony gibson's Avatar
I currently run a home made double pumper with 2 intake walbros...one of these pumps is acting up. They are both unrestricted walbros. Could I run the 400 with the other walbro 255? It looks like I could just clamp them together and plug it right in. Thanks for any input!
Old Nov 26, 2013 | 10:08 AM
  #491
IFuXwiTuZ's Avatar
im just curious to why no one would get this VS the BR DP KIT. its cheaper....the design looks better as far as the wiring / security of the FPs and it still hooks up to factory lines.
Full Blown Dual Pump
dont FLAME ME PLEASE im just asking.
xXANCHORMONXx I just wanted to say GREAT POST MAN ! im def doing this, i know you just saved me a whole lot more then $75 lol
Last edited by IFuXwiTuZ; Nov 26, 2013 at 10:28 AM. Reason: didnt see xXANCHORMONXx post
Old Jan 1, 2014 | 09:14 PM
  #492
V8s_are_slow's Avatar
Okay, I got to page 7 but I just couldn't take the bickering anymore, so sorry if the answer has already been posted. But what horsepower will the 400 pump support on "pump" gas? Or even race fuel? I don't have E85 in my area and it's not anything I'll ever be using.
I know the double pumper will support everything I need, but the cost is way up there compared to a single 400 lph pump. And if I'm not gonna be outflowing a single 400, then I can't justify the cost. Wanting to do it right though however, so that's why I'm asking. I'm using an HTA86 with an aluminum rod 2.3 motor in the works and 1250 high-z injectors, just for clarification.
Old Jan 1, 2014 | 09:48 PM
  #493
mrfred's Avatar
With the proper supporting mods, I feel comfortable saying 700 whp on gasoline.
Old Jan 2, 2014 | 06:40 AM
  #494
David Buschur's Avatar
The HTA86 will outflow the 1250 injectors you have EASILY and the single 400 pump is also not enough for that turbo, if it makes the power it should.
Old Jan 2, 2014 | 12:35 PM
  #495
mr evo7's Avatar
What would you say the 400lph can go to on e85 in terms on whp
