Walbro 400LPH intank pump ? Anyone got any info
Old May 31, 2012 | 03:46 PM
  #421
SOEuro's Avatar
Originally Posted by juanmedina
It seems that Titan Mortorsports is selling the pump already, do any EVOM vendors have them in stock?
edit:Mitsu Joe, How much shipped to 89031??
Old Jun 1, 2012 | 04:20 AM
  #422
way2qik's Avatar
Originally Posted by 3gEclipseTurbo
Will the walbro 400 fit in a double pumper? either buschur or full blown?
Yes. I have them in my Burschur DP.
Old Jul 17, 2012 | 09:50 AM
  #423
mrfred's Avatar
Originally Posted by David Buschur
As a side note, I may put one together and send it out to have the actual assembly flowed, my guess is the factory fuel filter and the way it's designed is going to choke that pump WAY down. When I get it together I'll ship mine off for flow testing and report back how it compares to just the pump flowing, I bet it drops 30%.
Did you ever flow test the stock pump housing?
Old Jul 18, 2012 | 05:51 AM
  #424
David Buschur's Avatar
No, the pumps sell but not nearly as good as the double pumpers. I feel they are just another cost involved that some people will choose to spend BEFORE they finally get the double pumper. That seems to be the pattern anyway.
Old Jul 29, 2012 | 08:53 AM
  #425
Drifting Away's Avatar
Yup...
Old Jul 30, 2012 | 08:03 AM
  #426
MitsuJoe's Avatar
BR is currently building one of these for a customer of mine with the E85 pump. I will post a few pictures when I get it as this is a new service they offer.
Old Jul 31, 2012 | 08:41 AM
  #427
Xenozx's Avatar
what happens whena pump fails, it doesnt lead to catastrophic engine failure does it?
Old Jul 31, 2012 | 09:57 AM
  #428
MitsuJoe's Avatar
Usually the pump will entirely fail so major engine damage is not much of a concern. I have seen a few occurrences where they electrically short out inside of the pump itself and that can be a bit messy but these are very seldom. Overall Walbro reliability has been very good and I have only seen 2 actually fail over time on the 50+ I have installed.
Old Jul 31, 2012 | 11:23 AM
  #429
Blue91lx's Avatar
I used to run a 255 inline before the rail as well as a 255 in the tank, rewired.
The tank pump failed, but failed intermittently, so I almost destroyed my motor as it kept randomly going lean. One day the back pump cut out all together, but that was after a week of tuning and trying to figure out why I would randomly go lean. Thank God forged internals are forgiving .
Old Jul 31, 2012 | 11:59 AM
  #430
Xenozx's Avatar
so if I was looking for 550 WHP or less on say a dyno jet (E85) but wanted a pump gas tune too (93) what would be the ideal fuel pump setup for the best price?
Old Jul 31, 2012 | 12:23 PM
  #431
MitsuJoe's Avatar
Blue91lx - I have never personal seen issues like that you have shown there but I typically always recommend a fuel pressure gauge so you can monitor your fuel pressure.
The Walbro E85 pump should meet your needs.
Old Jul 31, 2012 | 12:30 PM
  #432
Xenozx's Avatar
And I was thinking that, but I was reading somehwer the walbro E85 400 pump doesnt work well with pump gas at all?
Old Jul 31, 2012 | 02:51 PM
  #433
Geoff Raicer's Avatar
there is no reason the walbro 416 E85 pump can not be used with pump gas. Walbro 416 would be my recomendation
Old Jul 31, 2012 | 10:11 PM
  #434
Blue91lx's Avatar
The abnormal stuff normally happens to me. Now you can say you've seen a case where a Walbro failed slowly and almost caused a guy his motor.
I was tuning, doing pulls, and one pull would be lean, the other rich. I was so confused. I thought it was due to the temperature enrichment tables and the car was just switching between the two. Thus, I made both tables the same, went for a 3nd gear pull and gave me a good ole "bang" when I made full boost, and sure enough, it was completely lean.
It lasted for a day or so more doing the same thing, and then just stopped working all together. I used only the inline pump to get me around before my 400 came in .
Old Aug 6, 2012 | 05:26 AM
  #435
khasal's Avatar
E85 compatible Walbro - Pics
Picked up the E85 compatible Walbro 400 from Buschur last Thrusday.
Encountered fuel delivery issues after plugging it in the Evo. Currently troubleshooting with the guys at Buschur Racing.
I'll update the forum once the issue is resolved.
