Walbro 400LPH intank pump ? Anyone got any info
Old Jan 10, 2012 | 08:50 AM
  #361
drb's Avatar
drb
Originally Posted by David Buschur
We cut and ground on the stock retainer too but in the end I thought it took away too much of the integrity and I was afraid it would fall off over time. The hose clamp I personally think is a better idea, but that is just my opinion.
I don't disagree, I ended up using both the hose clamp and the stock retaining clip. Probably overkill but it's not hard to do.
Old Feb 29, 2012 | 08:12 AM
  #362
Lukelis's Avatar
thats mine
Attached Thumbnails Walbro 400LPH intank pump ?  Anyone got any info-img_0729.jpg   Walbro 400LPH intank pump ?  Anyone got any info-img_0730.jpg   Walbro 400LPH intank pump ?  Anyone got any info-img_0732.jpg   Walbro 400LPH intank pump ?  Anyone got any info-img_0733.jpg   Walbro 400LPH intank pump ?  Anyone got any info-img_0734.jpg
Old Mar 1, 2012 | 08:13 PM
  #363
420a-t's Avatar
I currently have a DW pump rewired, fuelab fpr, ad 1350cc injectors on e85. I need more fuel. If I install this with a rewire, will the return line be small causing any issues? Or will I have any problems running this pump, rewired with e85?
I also read earlier in this thread that a new pump will come out last month (Feb.) thats e85 compatible, is that true? Is there a new part number?
Thank you
Old Mar 1, 2012 | 11:28 PM
  #364
Lukelis's Avatar
final pics, decided to use filter from 255lph.
BTW maybe somebody have to sell their cap? Need one for a friend, please PM me.
Attached Thumbnails Walbro 400LPH intank pump ?  Anyone got any info-img_0746.jpg   Walbro 400LPH intank pump ?  Anyone got any info-img_0747.jpg
Old Mar 2, 2012 | 04:05 AM
  #365
catman78's Avatar
Nice job Lukelis,
The bevel in pic 2 is to seat the pump correctly so the end cap can fit?
Also, does the zip tie keep the clips from popping off.
Old Mar 2, 2012 | 07:08 AM
  #366
way2qik's Avatar
Originally Posted by ryuevoix
you trash talked to me in your initial response to my basic questions at the beginning of this thread. Pot meet kettle. I am by no means a follower and my car/ accomplishments are a direct example of it. after all, my stock block fp red setup w/93oct+meth beat your fully built fp red project white on e85 by half a tenth. Who was i following with that one dave? then i went high 9s on a stock block in the only evo over 3,000lbs . I'm a follower? Try again buddy. No need to get your panties in a wad.
lol!
Old Mar 2, 2012 | 08:00 AM
  #367
240Z TwinTurbo's Avatar
PM sent
Old Mar 2, 2012 | 01:31 PM
  #368
Lukelis's Avatar
Originally Posted by catman78
Nice job Lukelis,
Yeap Catman, the zip tie holding that cap very strong in setup like that
Old Mar 2, 2012 | 01:39 PM
  #369
catman78's Avatar
Anyone know the hp limit of this pump on Gas and E?
I was looking to get 600 on 93 with this pump on 1450's
Old Mar 2, 2012 | 10:04 PM
  #370
420a-t's Avatar
bump for an answer if someone is using this rewired with e85. Is it overrunning the stock return line? Is it needed to drill out the siphon tube?
I'm out of fuel on my fp black on 31psi and my dw301 pump, I need something bigger and don't know if this would be the solution or not.
Thank you.
Old Mar 3, 2012 | 10:00 AM
  #371
mrfred's Avatar
Thank you.
If you do the standard rewire that sends only high voltage to the pump, you'll definitely overrun the factory FPR and possibly the siphon hole. Doubt you'll overrun the factory return line. If you do a rewire like what I did, you'll likely be able to avoid any overrun issues with the fpr or siphon. Sorry, that's not quite the answer that you wanted, but best I can provide at the moment. Hoping to have solid answers in the near future when I try out this pump (have one in a housing ready to go but busy with other things).
Old Mar 3, 2012 | 11:53 AM
  #372
catman78's Avatar
looking forward to your testing mrfred, always great info...
Old Mar 3, 2012 | 12:15 PM
  #373
mrfred's Avatar
Doesn't a rewired Walbro 255 support 600 whp on pump? The burning question is definitely whether this pump can support 600+ whp on E85.
Old Mar 3, 2012 | 01:31 PM
  #374
catman78's Avatar
my 255 is rewired only. I tested to on 93 to 525 VD Dynojet. That was as much as I wanted to push stock block, so perhaps there maybe more
On E with a little less boost I was was getting lean up top.
so yeah, it's really what's the limit on E for the 400.
Old Mar 3, 2012 | 01:46 PM
  #375
420a-t's Avatar
That's what I want to know as well. I'm pulling the trigger on this or building a double pumper tonight.
I've been using a dw301 up to 34psi on my hta green, but on my black at 31psi, its not enough. At less that's a good way of telling I'm moving some more air lol.
