Quaife differential purchase
Old Sep 23, 2004 | 08:11 PM
  #286
Mike W's Avatar
Originally Posted by Zeus
Mike, any word on this "modified" feature that people are talking about?
All I know is that if you read it on the internet it must be true :-)
Mike W
Old Sep 23, 2004 | 10:07 PM
  #287
Zeus's Avatar
...something about a golden monkey flying out of the *** holding a winning lotto ticket?
Old Sep 23, 2004 | 10:52 PM
  #288
EVO_RPM's Avatar
This LSD is a direct fit isn't it?
Old Sep 23, 2004 | 11:14 PM
  #289
Mike W's Avatar
That's the whole point yes.
Mike W
Old Sep 24, 2004 | 01:58 AM
  #290
robi's Avatar
250 miles ran route 2 X2 I love this dif! feels just like the stocker untill I get to second gear on the boost corners when understeer trys to appear but then the fronts bite and the car tightens the radius back up... so faith and commitment will be required for these type of corners. (still going only 85-90%)
Old Sep 24, 2004 | 12:19 PM
  #291
tabio42's Avatar
I usually post on socalevo, this is my first post on this forum but I'm definately in for the diff and installation if there are still spots available because I think I just killed my front diff. I just hope it gets here soon...
1. gt40(socalevo.net)
2. Pesto360
3. evolunchbox
4. robi (center too) We need to do this right
5. chris in hb (from waaaaaaaaaay back)(socalevo.net)
6. xkpbreaker
7. blitzkrgCT9A(socalevo.net)
8. Silver Surfer
9.Themanofsteel
10. Trbo Dad
11. AK1
12. Mazdryk
13. kevo
14. denial
15. Syrihl
16. SoR
17. Evo8RA
18. Joe250
19. nsnguyen
20. tama_mog
21. chrisw
22. EVO RPM
23. QuickEvo
24. MarkSAE
25. jbrennen
26. scorke
27. MattGold
28. evo_dadi(norcalevo.net)
29. vtluu
30. smogrunner
31. RARIKLR
32. Tabio42
Old Sep 24, 2004 | 12:24 PM
  #292
marksae's Avatar
That is awesome news! Did you have any issues w/ the ABS acting up?
Old Sep 24, 2004 | 12:36 PM
  #293
2k4EvoVIII's Avatar
Im in anyword yet? Maybe i should make some calls!
Chris
2. Pesto360
3. evolunchbox
6. xkpbreaker
8. Silver Surfer
9.Themanofsteel
10. Trbo Dad
11. AK1
12. Mazdryk
13. kevo
14. denial
15. Syrihl
16. SoR
17. Evo8RA
18. Joe250
19. nsnguyen
20. tama_mog
21. chrisw
22. EVO RPM
23. QuickEvo
24. MarkSAE
25. jbrennen
26. scorke
27. MattGold
29. vtluu
30. smogrunner
31. RARIKLR
32. Tabio42
33. 2k4EvoVIII
Old Sep 24, 2004 | 12:43 PM
  #294
2k4EvoVIII's Avatar
Just got off the phone with Quiafe. They said they are getting 15 calls a day for these for the evo. This is what they had to say. The first ones are made and are being tested as we speak. THe problem is that they said from the time the testing ends it take another 6 months before they will be released. So we have good and bad news!!. They said cost will be around 1100-1299. They also said to call back in February 2005 and they should have everything ready to go.
Chris
Old Sep 24, 2004 | 12:47 PM
  #295
Guack007's Avatar
Awesome, by the time I can afford it it might be tried and true (and cheaper)
Old Sep 24, 2004 | 12:50 PM
  #296
2k4EvoVIII's Avatar
Just got off the phone with KAAZ and it looks like they already have them for our cars. They are 1.5 way lsd. Here is a chart showing what they got. Im waiting for a call back for availability.
FRONT = HELICAL/OPEN = DBM2060
CENTER = VISCOUS = DBM2070
REAR = MECHANICAL = DBM2031
Chris
Old Sep 24, 2004 | 12:55 PM
  #297
marksae's Avatar
Don't KAAZ diffs require KAAZ's special fluid which costs $$$?
Old Sep 24, 2004 | 12:59 PM
  #298
2k4EvoVIII's Avatar
A special blend oil made by KAAZ named "PowerTrain Gear Oil" can be used to keep your L.S.D. running for long hours under the best condition. The oil helps the clutch plates to grip and slip when needed.
That is off there website and all i can find is that it CAN be used. Nothing that says it must be used. But you might be right im not sure.
Chris
Old Sep 24, 2004 | 01:02 PM
  #299
2k4EvoVIII's Avatar
Kaaz LSD Gear Oil 80W90 2 Liter $44.50
Thats right off there webpage. It looks like all it is is 80W90 weight. But still not too bad.
Chris
Old Sep 24, 2004 | 01:29 PM
  #300
chrisw's Avatar
You could probably use any 80w90 weight gear oil with the friction modifiers for clutch type LSD's. I expect that the recommended fluid for the rear diff would be compatible.
