Quaife differential purchase
Originally Posted by marksae
Alright, I'm in the middle of installing my quaife right now and need an install tip.
What's the best way to chuck the front diff carrier down? I was able to crack the ring gear bolts loose by putting it on my vise. The gear teeth gave me enough grip to loosen the bolts. Now that I'm tightening, the gear teeth doesn't give me enough grip to tighten the bolts down since they're slanted in the wrong direction.
I know I can probably have a buddy come by and put some weight on the carrier. But I'm impatient and don't want to wait!
Mike W
Originally Posted by KZEVO
how about a review...ur thoughts on how kick *** this new diffy is
I'm about to go on a drive right now. I'll let you know what I think about it. My initial impressions are from my short test drive is that this thing ROCKS. I can actually go WOT through tight turns and the front wheels will keep gripping. Power understeering has been reduced significantly, if not removed completely.
can't wait for a detailed write up. if i had the cash i would get this in a hear beat
I think I actually felt some power OVERsteering on my test drive. I felt the rear of my car kick out when I mashed the throttle while entering a turn in 2nd. That's something I've never experienced in my EVO before! I'm scared to really test this thing on public roads, so I plan to bring my car to the next auto-x to really test it.
Originally Posted by nsnguyen
Man, I'm glad I found that PDF and that someone else had the knowledge and skill to put it to good use. Thanks again...
Please confirm that it is required to pull driver-side CV shaft, inner shaft, as well. Also what did you use to lube the o-rings?
Thanks
Thanks
Thanks
Thanks
Also, you need assemble the inner shaft to both CV shafts before putting them back in the car. I couldn't get my CV shaft to snap lock in place when I installed the driver's side inner shaft first.
*EDIT*
I used gear oil to lube my o-rings. There should be pockets of gear oil around the t-case. I just dipped my finger in it and ran it around the o-rings.
Yeah, you need to pull it. The snap ring on the inner shaft will hold the front diff carrier in place if you don't. You won't be able to pull the front diff carrier out of the transfer case otherwise.
*EDIT*
*EDIT*
Mark
