Gears Stuck
Old Oct 21, 2011 | 11:23 AM
saad601's Avatar
Gears Stuck
Hey Guys,
I'm having difficulty in getting it into gear ( especially Reverse) when at idle but gears run smooth when running on the road...???
I have a exedy twin installed and it recently ( less than 1500 miles on it) underwent a rebuild and it worked fine until recently... Car is only used on the street...so no hard launches...any idea what's wrong??
Changed the fuild to redline 2 days ago as well
i
Old Oct 21, 2011 | 11:32 AM
Ev0ikon's Avatar
Did you try to adjust the clutch pedal rod?
Old Oct 21, 2011 | 11:52 AM
saad601's Avatar
Yup..tried different positions..dint help..((
Old Oct 21, 2011 | 12:19 PM
kimma's Avatar
check the linkage that actually shifts it on the tranny..it could be the little plastic moon looking thing under the shift selector..it might be worn
Old Oct 21, 2011 | 03:43 PM
Murderedout8's Avatar
Try bleeding your clutch and seeing if your slave cylinder is in good shape. Another thing is mfaybe you have to much fluid evo trannys are picky and a tiny bit too much tranny fluid will make gears hard to go in sometimes.
Old Oct 21, 2011 | 10:29 PM
hereitcomes's Avatar
You can visually inspect both the master and slave cylinder in substantially less time. Either or will be leaking fluid if they are bad.
Old Oct 22, 2011 | 01:00 AM
saad601's Avatar
there are many threads on this where identical problem is present but thers no concrete response on how it can be corrected.....
Any experts want to shime in?
Buschur? Map , Mellon , Mike Awd?
weeeeeeeeee
May 17, 2016 01:21 PM
CBingg
Dec 25, 2015 02:16 AM
Mauricio Evo IV
Jun 21, 2012 08:24 AM
hakkoo
Mitsubishi TC-SST Discussion
14
May 21, 2011 10:23 PM
voltexct9a
12
Aug 10, 2008 01:48 AM
