Evolution Evolved- English Racing presents the USDM Auto Evo
Old Oct 24, 2011 | 08:18 AM
JohnBradley's Avatar
Originally Posted by WHTEVO
/\ I am sure of what trans is used but will not say anything in case they were not wanting anyone to know at the moment. It is from a US based suv as far as i know
Aaron
Look closer. Thats why I took pix of the bellhousing.
This is an Outlander-
Aaron
Old Oct 24, 2011 | 08:28 AM
EvoDan2004's Avatar
O baby. Hells yes. I can not wait to see how this works out. I have been dreaming of this day.
Old Oct 24, 2011 | 08:35 AM
R/TErnie's Avatar
Originally Posted by JohnBradley
Andrew tried breaking his ankle the first few days mashing the floor.
4.13 FD, gearing is pretty similar to the DSM auto actually.
Dunno but we are going to find out. One will be going in my car during the winter for testing and then race it next year. It is 30% larger than the DSM and has a much larger input shaft. We presume it should be able to do everything Jeff's car is given time.
Aaron
ooooh rah rah.
Great work English!
Nice write up Aaron. congrats on the success.
Old Oct 24, 2011 | 08:56 AM
B.J.@ToxicFab's Avatar
Nice job ER! Looking forward to more dyno & track results on how that Outlander trans will hold up!
Old Oct 24, 2011 | 09:01 AM
Its a Mitsu trans but look where the starter isnt at...Not Outlander, Hybrid.
Old Oct 24, 2011 | 09:02 AM
Boltz.'s Avatar
FCOTM Winner
In for vids.
Nice work.
Old Oct 24, 2011 | 09:13 AM
EvoDan2004's Avatar
Aaron what does the ecu need from the trans? Or vis versa. I am trying to see if it will work with the HKS F-Con/stock ecu
Old Oct 24, 2011 | 09:27 AM
Just a few inputs (TPS, RPM, a few others) as there is a separate trans controller for the auto. The motor continues to run the way its used to separate from the trans.
Old Oct 24, 2011 | 10:09 AM
94AWDcoupe's Avatar
This is very interesting. I thought about this swap idea for the evo 4 but didnt want to pursue it if GTA JDM parts had to be used. Be a pain to have to source GTA parts when they were needed. So this US trans swap is a good idea in my book. Will be watching to see what kind of power it holds.
I have plans to swap my evo 1 to auto. There are loads of early JDM turbo autos on importers shelfs. They come with converter, tcase. Found one shop with 20 sitting in stock. and they only want 150 a pop. And as strong as they are stock it doesnt make any sense to even invest any more money in them. Just blue wire mod, good clean oil, and let it rip. When it fails pop in another one.
Old Oct 24, 2011 | 10:14 AM
Jerry on those you can probably do a US 2G and then 3.307 ring and pinion swap I would think? We used a US trans as the base but it is much more than that now.
MechTech's Avatar
This is really cool! Great job guys. Ill be checking back to see the progress of this abnormality
Old Oct 24, 2011 | 10:30 AM
GregM's Avatar
Can't wait to see this. I know Airtreks with I assume is the same auto seem to start blowing them from about 400hp I think. Most that get modified generally swap to manual, which I don' want to do.
I assume you run 2 ecu's? This has been something I've been contemplating, running the factory ecu to control the auto and a 2nd one from an Evo8MR I have lying around to get bigger maps etc. I just need to get the ecu and loom plugs and then some motivation at the moment, which is hard to do when the car is running so well.
Old Oct 24, 2011 | 10:37 AM
ColinB's Avatar
Very Cool. Great work Aaron.
Old Oct 24, 2011 | 10:44 AM
Ahhhh, sneaky...I looked up the #s in the one picture...
Old Oct 24, 2011 | 11:40 AM
GregM's Avatar
My Airtrek runs a 3.3 FD in the W5A51, will the 4.13FD you have fit my box? And if so, what vehicles run that ratio that I could source the gearset from?
